originalcyn
Post by originalcyn »
primer coat number two!
Kijan
1993 Legacy LS | PBM 227
Danny-G
Post by Danny-G »
I moved these to here. Customized the factory mount to make it work.
And replaced the iginition switch bolt thingys (on the left) wiht real bolts (on the right).
Edit, I also modded the little pocket thing to fit in where the rear defrost and cruise control switches normally go, no picture of this.
Danny
jake15
Post by jake15 »
kimokalihi wrote:Jake you got a spare engine you don't need? lol
not an assembled ready to go motor, but i'm sure i have enough pieces to make something happen :)
HappyFrog
Post by HappyFrog »
Replaced a couple of vacuum hoses and narrowed my boost problem down to either boost controller or wastegate. Will look more into it later (when the turbo has cooled down).
Also disassembled the dashboard to get behind the instrument cluster and see if something had been undone as my speedometer hasn't worked for a couple of months. Unfortunately everything looked fine back there, so put it all back together. Wasn't as hard as I had feared though, so at least I learned a thing or two about the interior today 8)
Now being parted out
Danny-G
Post by Danny-G »
Mocked the custom grille for the first time.
Changed the drivers side fender and painted it even though its damaged.
And, moved the air horns to the right fender well, washed the air filter, and broke the stupid left marker light trying to put it on... damn those lights, you try to take it off the way the manual says and you break it.
Danny
HappyFrog
Post by HappyFrog »
Boost problem was caused by dirt in the dawes device, so after a good cleaning it was back to a healthy 22 psi :smt023
Left an Audi A6 3.0 TDI standing while playing, he almost came to a complete stop when passing me as I pulled over to turn around. I kindly returned the "Yes sir, your damn expensive diesel audi just got beaten by an old ass jap car in mid range acceleration"-look :lol:
CAV3MAN227
Post by CAV3MAN227 »
-Smogged the car yesterday and it passed no problem, even with a 3" DP and high flow cat.
-Joe
Jester808
Post by Jester808 »
Gave her a bath after several neglecting weeks. Really needs a paint job.
1993 Turbo Legacy Battle Wagon -Daily
1993 Legacy Wagon -STI Swapped *in progress*
1995 Impreza Swapped EJ20G -Sold
1997 Impreza Wagon, SCCA H-Stock Champion -Sold
1979 Brat 4x4 WRB w/ Full Rally Graphics -Sold
2002 Impreza Sport Wagon GT40R -Caught Fire
Danny-G
Post by Danny-G »
Up-dated the cruise and rear defrost swich with a set from a '97 outback, and put the driving light switch in. Re-did the lower switch panel thing, put in a non power mirror filler plug, and drove it after driving a '99 LGT for the past few days.
Danny
originalcyn
sanding and primer coat number 3!
Kijan
Jester808
Post by Jester808 »
Replacing a lot of old ugly dirty nuts and bolts inside the engine bay with newer polished ones with yellow zinc coated washers to make it look all pretty and stuff :).
SLODRIVE
Post by SLODRIVE »
Swapped downpipes and changed the oil tonight. E-test tomorrow...
http://www.slodriveracing.com
-And more!
SubyFusion
Post by SubyFusion »
Just turned over 160,000 today even thought its really only been like 7,000 for me hahahah
1992 Legacy L (AWD )(5MT)[2.5RS Trans] EJ22T Swap in Progress
originalcyn
Finally went and got Nissan Silicone Lubricant. More sanding and primer on the grille. This will never end.
Kijan
i drove my car hard from n. tacoma to roy (minus the traffic.)
It was fun :)
originalcyn
bumper filler for the grille. we'll see how that goes...
Kijan
Danny-G
Post by Danny-G »
Finished removing the wiring for a sub and amp, and moved my driving lights to the top of the bumper.
Danny
originalcyn
Tire psi.
Silicone lubricant for the sun roof.
Sanding sanding sanding.
Trying to paint a badge. Any one have any idea how to remove chrome from the badges? With our badges (at least the 92-94) i don't seem to have too much trouble getting the chrome off. but i'm working with a forester badge now and the chrome doesn't seem to come off that well.
Kijan
Vacumed my interior... armor all wipes for the rest tomorrow...
Danny-G
Post by Danny-G »
Moved my stock horns, swapped a driving light housing, used Meguiars Plastix, and taped the hell outta the left headlight hopefully sealing it for the rainy season
Danny
Jester808
Post by Jester808 »
Partially disassembled my TD04L for some refurbishing:
Finshed refinishing the Oil Lines:
Danny-G
Post by Danny-G »
Got real foglights from the junkyard for five bucks and they work, and while there also melted a gas guage needle so I could get tha gauge piece and lastly got a set of brackets that hold the engine cover down that have the rubber things in them. Oh and I took a drive on a dirt logging road with all the lights on :).
Danny
Danny-G
Post by Danny-G »
Updated the wiring coming from the fogs, mounted them, and re-furbished the solid covers from flat black with the word blazer in white to mica black with Subaru spelled out on them like S U B A R U the letters came off an Impreza trunk.
Danny
kleinkid
Post by kleinkid »
Danny-G--Being that you are over there on the peninsula, you may know about A and G Import Auto in Port Hadlock-Irondale. Between Port Townsend and Chimicum. They have a lot of Subaru used parts and even a couple of Sport Sedans in their yard. 360-385-0002.
Danny-G
Post by Danny-G »
kleinkid wrote:Danny-G--Being that you are over there on the peninsula, you may know about A and G Import Auto in Port Hadlock-Irondale. Between Port Townsend and Chimicum. They have a lot of Subaru used parts and even a couple of Sport Sedans in their yard. 360-385-0002.
I've heard of them before and I believe I've been there once.
Danny
