Pedal Assembly Removal
SubyFusion
Does anyone know of a write-up on how to remove the pedal assembly?
1992 Legacy L (AWD )(5MT)[2.5RS Trans] EJ22T Swap in Progress
SubyFusion
Re: Pedal Assembly Removal
do you have to take the dash out? or just remove the steering column?
You don't remove anything but the pedal assembly aside from the lower dash panel. From memory there are four bolts that go through the firewall to the brake booster. Un-bolt those and pull the booster/master cylinder away from the firewall under the hood. Another bolt goes straight up above the gas pedal. Un-plug the brake switch and the clutch switch (unless you have an auto
) and pull!
SubyFusion
Its a Hydraulic pedal assembly so its all one piece, and I cant get it around the steering column
Oh yeah, I've been playing with these NA's so much latelely, I forgot about that possibility! I have removed the pedal assembly out of my '91 SS, and I do remember having to pull the steering column out, sorry. I've never pulled a dash yet, so I know you don't have to resort to that to get it out.
Undo the bolts on the steering column so it'll drop down a little bit. Then the pedal box should have enough room to slide over it... so I seem to recall from removing one last year.
'11 WRX Limited
'94 TW | R.I.P.
SubyFusion
Thanks droped the steering column and it wiggled right out!
