timing covers
timing covers
On my ej22t can i remove timing covers without removing alt - ps - ac? I think timing belt is snapped, compression is very low.
84 twagon
Hey Mang, how you doing? IIRC you don't need to remove the actual units but you do need to remove the belts and one of the tensioners. You'll have to take the radiator fans out too. Take off the crank pulley ect.. If you have a Haynes manual it walks you through it pretty good. If you don't have a Haynes manual I suggest getting one( they're cheap and handy). If you're going to go through the trouble of getting in there to do the belts I suggest replacing the front seals and water pump too and maybe even the oil pump.
How's the rebuild coming? Did your heads check out ok?
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
- quasi-mod-o
local
You know what...if I should replace all that stuff...I might as well just buy a used engine. I found an engine locally, they want $1000 for it. It has 71,000 on it. Its out of a 94 & just came into the yard in 2003....they'll give me 30 day warrenty.
84 twagon
Uh, but for all you know, the water pump and oil seals in that engine are all old too... And you don't know how well the previous owner(s) have treated it.
Timing belt/water pump/oil seals is a pretty standard maintenance job.
5 minutes if you don't have an old 4eat rad that hasn't been removed in a long time.subyluvr2212 wrote:If you're gonna do the timing belt, might as well do water pump and oil seals like Matt said. If you're gonna do water pump, you're gonna hafta drain the radiator anyway, so might as well take it out. It's a whopping 5 minute removal and the few inches of extra room is WELL worth it!!!
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
