Manual Boost control install?
I have an ej20 and am not familiar with the vacuum lines. I have it hooked up like this. Is this correct? Its a turbosmart bleed off type.
Re: Manual Boost control install?
Came this this diagram with your mbc? Then I guess it should work as it should. What kind of boost reading are you getting?
One question about this type of mbc by the way. Why do some have a seperate t-piece and a boost adjust like this one, while others (GrimmSpeed, Dawes device) only have one component in the line between turbo and wastegate?
Personally, I'd prefer a blocking type boost controller over a bleed type. The blocking type boost controllers allow for boost to build quicker compared to the bleed types. The bleed types may be better at controlling spikes and overboost, but a properly setup of blocking type works fine.
Legacy777 wrote:Personally, I'd prefer a blocking type boost controller over a bleed type. The blocking type boost controllers allow for boost to build quicker compared to the bleed types. The bleed types may be better at controlling spikes and overboost, but a properly setup of blocking type works fine.
Any suggestions for a brand or website?
The Joe P Pro-Z MBC's are nice. I ran one for a while.
http://www.joepmbc.com/
http://www.main.experiencetherave.com/s ... s/joepmbc/
