td04 questions
td04 questions
I have a td04 i have everything I need but I wanted to replace the copper washers on the coolant and oil lines. Where do everyone here get them? I have everything except for those new washers. All help would be appreciative.
94 legacy gt turbo
pics! http://bbs.legacycentral.org/viewtopic.php?f=9&t=45358
Re: td04 questions
Tried a hardware store?
'11 WRX Limited
'94 TW | R.I.P.
Re: td04 questions
Yeah they don't have copper washers. I've looked at 3 automotive places and lowes and no luck.. Ik there prolly is a p/n but I can't seem to find it anywhere.
94 legacy gt turbo
BoostedSubie
Re: td04 questions
Josh has the factory service manual with all the part numbers on his website: surrealmirage.com . I would look it up for you but i'm on my cell and it won't let me download it. It is something handy to have so i'd download it if i were you.
93 Black Legacy SS
93 Legacy
97 Green Outback
97 Red Legacy GT
99 Black Legacy GT wagon
93 Legacy
97 Green Outback
97 Red Legacy GT
BoostedSubie
Re: td04 questions
Also, i forgot to add, Ebay has kits that have them included for cheap.
93 Black Legacy SS
93 Legacy
97 Green Outback
97 Red Legacy GT
93 Legacy
97 Green Outback
97 Red Legacy GT
Re: td04 questions
Ah ok I'm gonna check out joshs website and then eBay. Thanks!
94 legacy gt turbo
Re: td04 questions
Re: td04 questions
isnt the copper washers different sizes from the vf11 and the td04 tho?
94 legacy gt turbo
Re: td04 questions
They use the same size fittings.
Re: td04 questions
Well next to eachother they are different I can take pics. But for the stock vf11 they have a smaller od then the td04.
94 legacy gt turbo
Re: td04 questions
I'm pretty sure I'm using vf-11 hardlines with my td04 but I could be mistaken. Why not take the bolt(s) to say Lowes or Ace hardware and match it with copper rings?
Re: td04 questions
I would but that's the problem I can't find anything close to the same size... This is like the only thing I need left to do to my car to finish the swap...
94 legacy gt turbo
Re: td04 questions
well i bought a kit off ebay today. it came with a bunch of stuff i dont need it all but itll be nice to replace more things. i hope its not cheap crap. but it should do...
94 legacy gt turbo
BoostedSubie
Re: td04 questions
When i first did my swap i bought one of those kits and i've been using it for almost a year now, no problems. I've had my turbo on and off every other month too and reused the washers, still no leaks or problems. So, you should be fine.
93 Black Legacy SS
93 Legacy
97 Green Outback
97 Red Legacy GT
93 Legacy
97 Green Outback
97 Red Legacy GT
Re: td04 questions
Alright sweet thanks! That makes me feel a little bit better about buying the kit now. I got all the coolant lines with all the washers the turbo gaskets that connect to the exhaust. A stainless steel braided oil line and the oil return on the bottom of the turbo. All new i forget what they are called now but the bolts for the coolant and oil lines. I feel like I'm missing something. But there was a lot and it was only 55 that's including shipping. So I couldn't resist really. I'm anxious to get my car back running! Now all I need to do to finish is new valve cover gaskets, and I'm gonna do the silencer delete. Then All new coolant and do a oil change.
and it will be all ready. Can't wait. I'm excited!
94 legacy gt turbo
Re: td04 questions
So I hooked it all up. Got rid of my turbo silencer. It sounds great! But I drove it and well I maxed the injectors and maf just driving it. I didn't know want was going on. So I putted home going 20.... Totally embarrassing. Then i noticed i didnt have my wastegate solenoid hooked up. So i Hooked it back up. But see my question is what do I do? I unhooked the battery and let it sit for about an hour hooked it back up and it idled rough and I drove it only meeting 5psi.... And it was driving real rich and crappy... So what should I do?
94 legacy gt turbo
Re: td04 questions
How do you know you maxed out the MAF and injectors with out data logging?
'11 WRX Limited
'94 TW | R.I.P.
Re: td04 questions
Well I figured I did so that's why I unhooked the battery. And reset the ecu. They would be fixed now right?
94 legacy gt turbo
Re: td04 questions
It was running great up until it boosted that high.
94 legacy gt turbo
Re: td04 questions
Got a link to the oil line u bought? I'm trying to find one fir my td04l
93 legacy l
to much to list....
to much to list....
Re: td04 questions
I got it on eBay from authentic boosting get the kit. It'll give you everything you need.
94 legacy gt turbo
Re: td04 questions
Is the check engine light on?
Re: td04 questions
i just did this swap. The lines are almost i idnetical. I mean there are slightly different bends but i used the stock vf-11 oil line and slapped that bad boy on the td04 ( I did not have the td04 line so i had to make it work, but it was seriously like 99% close enough). You do have to twist it a tiny bit to get it to fit I did not have to mod it in any way. I just used some 200 grit sand paper i had laying around and rubbed the washers a little bit so the mating surface would be clean. Wham, bam, thank you ma'am, no leaks.
1990 NA 2.2 Open Light rally car
