Hi,
Does anyone know if a jdm ej22 crank fit in a ej22t?
I know the thrust is located on the #3 also ....
Thx
Crank differences Jdm ej22 vs ej22t
Re: Crank differences Jdm ej22 vs ej22t
I didn't think they sold a 2.2 in Japan, but I would seriously doubt there's a difference. I can't see a difference between the turbo and N/A cranks.
22b maybe?
If it's really the 22b crank then it's phase 2 with a different thrust bearing location from the ej22t.
So it's an aftermarket crank. You'll have to ask them if it's phase I or Phase II, or possibly machined for both. If it's phase I or both, then it'll work. To be honest, though, the ej22T crank is forged, and is strong enough for all but the highest HP builds. And the dealer still stocks them.
Part # 12200AA150 (which is the same part # for both EJ22 turbo and n/a)
Yeah, the bottom end parts of both USDMs are forged—cranks and rods. Buying N/A EJ22 might be cheaper, too.
thx everyone, I'll keep my ej22t crank then and micropolish it!
Details of my build:
EJ22T Block
EJ22T crank
Custom CP pistons (8.5:1->EJ20G heads)
Eagle rods
Legacy EJ20G Heads
Planning on fmic, don't know what turbo and manifold to go with .... anyone have a similar setup?
EJ22T Block
EJ22T crank
Eagle rods
Legacy EJ20G Heads
