Issues with removing the transmission.
Weston_Duyck
So I need to get the CV apart from the auto tranny and I can't figure it out...help?
93 Winestone Subaru Legacy L AWD-BROKEN
86 White Toyota 4Runner SR5 4x4
---Girls love it when I hit it sideways(It's a DRIFT thing)---
Re: Issues with removing the transmission.
Did u knock out the roll pin that holds the splines together?
90 legacy Wagon LS Special, JDM closed deck 20g, custom 25d heads f/ metic motors, APS GC FMIC, 740cc, VF34, 4.11 F/D, Turboxs RFL blow off valve, now with piggyback.
94 Legacy SS R.I.P (parts car now for 90)
97 Legacy Outback (sold)
Weston_Duyck
Ya I got the pins out and then I took the stut to hub mount bolts off and got it
just the other side is very stuck
Pb blaster, I love it!
Weston_Duyck
I've used liquid wrench, then broke my ratchet and then tried a impact wrench and still nothing
Try some elbow grease, but I think you can only get that in a 55 gallon drum.
Weston_Duyck
Finally got it, tranny is out but the TC got stuck on the motor. So I'm at a lost on how to get that thing off
On the engine bellhousing, is a black plastic cover. Remove that and you can access the bolts holding the TC to the flex plate. Note since you pulled the TC and motor still connected, there's a chance you messed up the tranny's input seal. I'd highly recommend replacing that. I didn't once, and had to pull engine again. The tranny? Well it was a gusher, lol, till I replaced the seal.
Weston_Duyck
Shit. I should of thought of that, well hopefully nothing got to messed up.
