Info Needed: WRX to Legacy Front Brake Conversion
FrmRgz2Rchz
Is there a write-up out there on the parts needed and the installation procedure?
Andy Rose
1993 Subaru Legacy Sport Sedan
2003 Subaru Impreza WRX
2004 Subaru Impreza WRX STI
1999 Hyundai Accent
1999 Hyundai Accent
All you need is the WRX caliper bracket to clear the larger rotor. Finding a used WRX caliper and bracket usually isn't hard since they all do big breake kits also. Or $80 from the dealership each
. Install the rotor & caliper just like the old one came off. You'll need 16" wheels to clear, also.
To clarify, you are asking about installing WRX front brakes onto a legacy, right?
I'm pretty sure you do need the WRX caliper as well. I don't think the stock caliper will fit onto the WRX bracket.
FrmRgz2Rchz
nope....just rotor, calipers, brackets, and of course larger wheel.
There are bias issues too that may come up......but depending on how picky you are about your brakes, you may not notice it.
you're just not picky enoughBrat4by4 wrote:You won't.
Heck, I'm too used to sliding around in the dirt and snow in my brat. Running unrated tires all-year round. I'm more rally than road. I hate that it is so difficult to get my back end out on the legacy. Heavy handed front brakes unloading the rear end is right up my alley.
Yeah.....my car is definitely more of an on-road setup. I want to step on the brakes, throw people through the front windshield and have the car not get squirmy.
Right now with my setup.....I pretty much have that......
FrmRgz2Rchz
I'm not exactly sure. I think the caliper piston size is the same, but as for how it mounts to the bracket......if it similar to the early legacy calipers, you will need the 2.5 RS calipers to match its bracket.
Also....I sorta seem to think the 2.5 RS has the same size rotors as the turbo legacy..... I don't think you'd be gaining much braking increase with the RS brakes.
FrmRgz2Rchz
I don't think i phrased my question exactly how I wanted it answered. Still talking about the WRX conversion, the only thing the RS boys have to do is buy the bigger rotors and the bracket that the calipers mount to. I was wondering how much different our calipers are from the RS. If they are similar, why not just buy the rotors and brackets from a WRX? I think that is a little better.
Andy Rose
1999 Hyundai Accent
1999 Hyundai Accent
There is conflicting info on whether our calipers will work or not. I think you'll just have to borrow a WRX or RS bracket and see if your caliper will fit. Then you will be able to give us a definite answer.
But finding WRX calipers shouldn't be too hard since everyone is trying to upgrade to 4-pot or larger. I got mine (caliper + bracket) for $40 shipped.
I looked at the manual.....they are different. Our's uses a guide pin at the top that the caliper slides on, and a bolt on the bottom.
The WRX caliper bracket has two guide pins that bolt onto the bracket.
