recommended wideband kit
im looking for a wideband kit i was looking into more the aem uego wideband kit or the innovate lm1 kit which one is better or what do yall recommend? thanks!
							94 legacy gt turbo
pics! http://bbs.legacycentral.org/viewtopic.php?f=9&t=45358
Re: recommended wideband kit
I'm rocking the LC-1. I dont know where you're located, but if in washington, theres a guy selling a "new" aem for like $160 on CL.
							1994 Legacy Sport Sedan.
1991 Legacy Sport Sedan.
Ah damn I'm in Ohio.. Do you like the lc1?
							94 legacy gt turbo
I like it. I had the o2 sensor burn out on me after like 3000 miles, which i wasn't happy about. I dont know if it ws because my car was/is running SUPER rich at idle or if it was just a faulty sensor. I bought another for like $45-$50 from autozone and its all good, for now. I only have about 1000 on this one, lol.
I too have the LC-1 and XD-16 gauge.  Works well, although one must calibrate it every 3-6 months like the manual states.  Otherwise it some times forgets what AFR its using.
additionally, the LC-1 is one of the only gauges which properly detects when the wideband is defective -- other sensor units do not.
'11 WRX Limited
'94 TW | R.I.P.
Ok how do you recalibrate it? Is it hard can you do it by yourself?
							94 legacy gt turbo
Can you change the af ratio with the gauge or using the data logging stuff. I'm a big noob when it comes to the more higher tech things I guess. Or anything in that nature really.
							94 legacy gt turbo
If you wish to learn how a specific wideband sensor works, I'd strongly suggest downloading the manual from the manufacturers website -- any respectable company will have them online.
Yes, recalibrating the LC-1 with XD16 is done via a few button presses. Yes, the LC-1 you can set any AFR ratio you wish via a PC and their software; along with changing the narrow O2 output curve.
'11 WRX Limited
'94 TW | R.I.P.
Alright well sweet. I was kinda leaning towards the aem but now the lc1 is looking pretty good.
							94 legacy gt turbo
Do you use the o2 sensor it came with as your primary? Or do you still have your stock one in place then running a separate one for your wideband?
							94 legacy gt turbo
I'm separate. Left the stock one alone, and am running my wideband strictly as an a/f measuring device upstream of the cat.
