Couple of engine issues, trying to solve
94LegWagon
Post by 94LegWagon »
Hi, my 94 legacy N/A recently feels like it is misfiring on the freeway when/if I turn the AC on, under light throttle, going maybe 75mph. The second thing is that sometime slowing down for a stoplight or stop sign I put it into neutral and the revs hang at ~2000 rpm, and stays there hanging until I engage the clutch again, mostly happens before the engine is fully warmed up. Any ideas on what could be causing these issues? TIA
94 Legacy Wagon N/A 5mt AWD
Re: Couple of engine issues, trying to solve
Have you checked the normal stuff, plugs, wires, etc?
The idle issues may be something with the IAC valve or may be a result of something else.
If you can provide any additional details on any recent work that will help in providing you direction.
lucas
Post by lucas »
take it from me if its the IACV dont mess with it unless you know for sure what your doing.
1993 legacy ss "Shela"
