I looked threw about 10 pages but no luck
So
for the 1991 subaru legacy Sport, What are the stock gearing?
Example: http://www.catherineandken.co.uk/sti/trans.html
Stock gearing
Re: Stock gearing
It's in the Owner's Manual, but I found it in the '92 FSM, too - same as '91, I believe:
You don't state which transmission, but the two columns on the right are for the turbo. Look under 'DSPD' for the 5-speed manual; under 'TC' for the 4EAT.
Here's the full page:
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
Re: Stock gearing
Or also found in this forums stickies... http://bbs.legacycentral.org/viewtopic.php?t=27119
'11 WRX Limited
'94 TW | R.I.P.
Re: Stock gearing
perfect thank you!!
Last question, does a lower number mean Shorter gears? and a higher number mean taller gears?
Re: Stock gearing
Smaller number means taller gears and faster you'll go. Larger number means more gear (engine speed) reduction and shorter gears.
