Did you know your hood will open straight up?
I never noticed until last weekend. Your hood will actually open straight up without binding. There are two metal clips which stop it from going further than a 90 degree angle.
It makes a HUGE difference when working on the car. Just be sure to use a bungy cord or similar to hold it, as a small gust of wind may cause it to fall.
Yeah, I often prop my hood all the way up to reach the back parts. Like you said, you just have to be careful because it's essentially a big sail; wind can not only blow it down on your head but also overpower the hinges and slam it into your windshield.
The rod that holds it up pops out from by the rad and fits into a bracket on the strut tower (at least it does on my 92). Holds it almost at its full travel. I used it when changing the tube for the PCV system that I broke.
yup....you can remove the hood prop lever and reverse it to go in the strut tower bracket......it's in your owner's manualmikec wrote:The rod that holds it up pops out from by the rad and fits into a bracket on the strut tower (at least it does on my 92). Holds it almost at its full travel. I used it when changing the tube for the PCV system that I broke.
I was also quite excited when I found this out, so far I haven't needed to have it more that the normal height, but think of the possiblities.
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
My brat would do this also. It was an 85-some degree angle but it would hold it there.
The valve cover gaskets have gravity and pressure pushing on them... you can't release the gravity pressure unless you were to systematically flip your car over at night. That's just an inherent negative in the boxer engine layout, which I think is overcome by a barrage of positives.
QuickDrive
- Lurker-King
legacy92ej22t
I did not know about using the hood prop on the strut tower.
I've had this car almost 7 years and never noticed it. That's pretty cool.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
eastbaysubaru
- quasi-mod-o
My old GL10 did that too. It also had a spare tire over the engine. When I had to use it for the first time the rubber was soo baked that it split in two and the tire was no good. They were a special tire meant to withstand the heat, but when the owner before you blows the engine and the tire has never been used in 160,000 miles, something's bound to give.
91 Pearl White Sport Sedan
2014 Volvo S60 T5
18 KTM 1290 Adventure S
97 Toyota 4Runner SR5 - sold
2002 BMW r1150rt-p - sold
2004 BMW r1200ST - sold
2016 BMW r1200RS - sold
2014 Volvo S60 T5
92 Le-Turbo-SS
ciper wrote:WOW[/size
Okay, Ive decided the legacy design engineers are officially the best ever (except for the guy who made the sun visors, rear door handles and valve cover gaskets)
Don't forget the idiot who designed the infamous dual cup holder above the radio
[quote="Yukonart"]Take what money you have left, buy some beer, and drunk drift that biatch later tonight! :lol:[/quote]
it's actually quite convenient if you have a remote, though they could be a few centemeters farther apart, but then again, I've always got my crotch. Which btw is great for hot days
Ryan, I noticed the same thing in a loyale(i think not 100%) I saw, was there just no room in the trunk area or was there something else?
- quasi-mod-o
I've done it in many manuals, but I think thats jus because my legs are so long and I'm usually in compact cars, I also don't drive fast when I have a drink there, nothing worse than clutching quickly and having 32oz of root beer all on your feet and carpet. I do some crazy stuff in cars, like one time I shifted all the way to fifth on this semi windy road without using my arms for anything, that was so fun, But now that I look back on it kinda stupid.
If I have a large drink from taco bell that is about 4 drinks less than full it will press the power button on the radio in my wagon (but not the other cars).
It took me a while to figure out what the heck was happening. If the drink is too full it created too much friction and the cup holder was still. Too empty and it couldnt press the button!
I can make it stop if needed
