93 EJ22T Parts heads, injectors, fuel rails, turbo , more
vica153
Post by vica153 »
I'm finally getting around to taking apart my old EJ22T, so I have some parts to sell. The engine only had 3k on it after being resealed and somewhere around 175k total. It was running perfectly. All day long, 4 days straight, including a couple mountain passes, the day after I dropped it back into the car.
Not selling the block.
--Stock pink sidefeed fuel injectors and rails - $25. --sold--
On 3 injectors I broke off the little nub that the connector snaps onto. I was being careful too :x . The connectors stick onto the injectors so tightly I still wouldn't be worried about them coming off. I don't feel like messing with the crusty old phillips head bolts, so the rail, injectors, and FPR are a package deal lol.
--Intake elbow, turbo <-> resonator, $10 --sold--
--VF11 turbo - $25 --sold--
--Heads + valve covers - $25
One exhaust manifold stud came out with the nut. One intake manifold bolt snapped.
--Intake manifold - $10 , no TB or IACV
--Coolant reservoir -$10 ,
One of the nipples cracked off and I threaded in a brass fitting in its place and put some JB weld on to seal it. Always planned on replacing it, but it ran like that for 3 years without a problem.
--Canister purge solenoid -$15
Bought new 4 years ago, 25k or so on it now
--Clutch master & slave cylinders & reservoir. $10
--Timing belt cover pieces, $5
Both passenger side sections and the front driver side section. The others are damaged.
--Charcoal canister $5
--Timing belt tension adjuster and tensioner pulley. --$50
New from Subaru June 2010. Used for ~2 weeks. Less than 3k miles on them. Close to $200 for both new. I'll toss in the mounting bracket too.
--STi up pipe $40
Off an 05 if i remember correctly.
--MAF sensor $20
--EJ22T rods $10 --sold--
--EJ22T pistons $10 --sold--
vica153
Re: 93 EJ22T engine parts heads, injectors, fuel rails, turb
Post by vica153 »
lucas
Post by lucas »
got any of the air intake parts?
1993 legacy ss "Shela"
vica153
Post by vica153 »
Yep all of the intake parts are for sale, including the MAF sensor.
injectors sold.
aldogg
Post by aldogg »
Is the turbo in good shape? and do you still have the air intake parts?
vica153
Post by vica153 »
I can feel just the tiniest bit of shaft play in the turbo. It was working great last time the engine ran, I wouldn't hesitate using it again if that's where my build was going.
I have all the intake parts, except for the one rubber elbow that connecters to the turbo inlet.
vica153
Re: 93 EJ22T Parts heads, injectors, fuel rails, turbo , mor
Post by vica153 »
Added a few more parts. OBO, just want to see the parts go to a good home :-D
chochocho
Post by chochocho »
pm'd you.
darkcrave
Post by darkcrave »
sell just the cams in the heads? price shipped to 95205
pictures on the timing belt pulleys?
Tune
TMIC
Fuel
Taillight
Omega79
Post by Omega79 »
Might have to see if a couple things are still around when I finally have dough. Have a buddy that used to be on here all the time that will be interested in a couple things as well, I'll let him know...
lucas wrote:There were multiple Legacys with 300k+ miles. Jesus will return on a Turbo Lego.
vica153
Post by vica153 »
darkcrave wrote:sell just the cams in the heads? price shipped to 95205
Nope.
Omega79 wrote:Might have to see if a couple things are still around when I finally have dough. Have a buddy that used to be on here all the time that will be interested in a couple things as well, I'll let him know...
Ok.
darkcrave
Post by darkcrave »
Ill pay the 25+ Shipping i just dont want to pay the shipping for the whole head when i only need the cams
Tune
TMIC
Fuel
Taillight
vica153
Post by vica153 »
bummmmp
vica153
Post by vica153 »
Bump for timing tensioner goods
imaiami
Post by imaiami »
got the stock map/ turbo pressure sensor? part num 22012AA020
thanks,
dustin
vica153
Post by vica153 »
It should be around somewhere, but I can't seem to find it.
turboroman
Post by turboroman »
intrested in purge sylonoid,and knock sensor, any auto trany? need front diff.........
mysuby
Post by mysuby »
interested in the heads, and the rods, and maybe the pistons...pm me please
vica153
Post by vica153 »
Lots of stuff sold.
Practically new old style timing belt tensioner and pulley still available.
