Okay, so today I desided to throw my 17in rota grids on.
First off; rubbing on the struts in the rear.
Add spacers
No more rubbing
Now under hard/slight turns I have rubbing in the rear fender, which is shaving rubber off my tires.
I have KYB struts in the rear but is it possible my springs are gone?
Would som new suspension help?
About that time???
Re: About that time???
What offset are the rims, and what size spacer did you put on?
You will likely have to shave or roll the inner fender lip
Yeah when i first put 17's on my car I had to roll the fenders in the rear. I also had some rubbing on the strut with my new BBS wheels but instead of getting spacers I just pounded the spring perch in a little bit so the tire would fit. Yeah Im a red neck.
