Okay, so today I desided to throw my 17in rota grids on.
First off; rubbing on the struts in the rear.
Add spacers
No more rubbing
Now under hard/slight turns I have rubbing in the rear fender, which is shaving rubber off my tires.
I have KYB struts in the rear but is it possible my springs are gone?
Would som new suspension help?
About that time???
Re: About that time???
What offset are the rims, and what size spacer did you put on?
You will likely have to shave or roll the inner fender lip
93legacylsleeper
Yeah when i first put 17's on my car I had to roll the fenders in the rear. I also had some rubbing on the strut with my new BBS wheels but instead of getting spacers I just pounded the spring perch in a little bit so the tire would fit. Yeah Im a red neck.
