Air to Coil??
Air to Coil??
Hi guys, I have a 90 liberty wagon and I want to get rid of the air suspension...will WRX struts and springs fit it??
At the moment I have jacked the car up then started it then lowered the jack and the car is sitting on the bumpstop then i start it and let it pump up about 1.5 inches then i pull the fuse out for the shocks and my car is instantly lowered...hehehehe
Can this damage anything??
Cheers
Jaskel
Cheers
Jaskel
Boxem Up [url]http://www.iinet.net.au/~jaskel/Recording2.wav[/url]
Visit this awsome Liberty site; http://www.rslibertyclub.org
My Photo Album; www.fujicolor.com.au/Jaskel
conversion
Hi, ive got a liberty wagon with the air suspension too, how did you go with the conversion? have you noticed any damage from lowering the car they way you said? Im still trying to figure out what it was you did? how much did it lower the car by?
philhustler: I dont know exactly what you are referring to.
The conversion is to basically get suspension from a normal Legacy. I did this first. THEN later I switch to non tapered rear springs and Impreza struts. I lowered the car using whitelines set of springs specifically for the Legacy.
it lowered it a couple inches... here is a pic...the back is sagging a litlle...raise it about an inch and thats it....i would still like to do the spring conversion..
Why everyone want to convert to springs instead of air?
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
I'm just curious, I don't have the money for struts right now and if I did i'd most likely be going with gr-2's or some impreza coil-overs
