Air to Coil??
jaskel
Air to Coil??
Post by jaskel »
Hi guys, I have a 90 liberty wagon and I want to get rid of the air suspension...will WRX struts and springs fit it??
At the moment I have jacked the car up then started it then lowered the jack and the car is sitting on the bumpstop then i start it and let it pump up about 1.5 inches then i pull the fuse out for the shocks and my car is instantly lowered...hehehehe
Can this damage anything??
Cheers
Jaskel
Boxem Up [url]http://www.iinet.net.au/~jaskel/Recording2.wav[/url]
Visit this awsome Liberty site; http://www.rslibertyclub.org
My Photo Album; www.fujicolor.com.au/Jaskel
JasonGrahn
Post by JasonGrahn »
-Jason Grahn
jaskel
Post by jaskel »
thanks for that..i will check it out
ciper
Post by ciper »
A couple members have done this conversion. Ive actually done it twice on subarus, feel free to PM me if you get stuck.
philhustler
conversion
Post by philhustler »
Hi, ive got a liberty wagon with the air suspension too, how did you go with the conversion? have you noticed any damage from lowering the car they way you said? Im still trying to figure out what it was you did? how much did it lower the car by?
ciper
Post by ciper »
philhustler: I dont know exactly what you are referring to.
The conversion is to basically get suspension from a normal Legacy. I did this first. THEN later I switch to non tapered rear springs and Impreza struts. I lowered the car using whitelines set of springs specifically for the Legacy.
philhustler
sorry my post was referring to the first post of Jaskel, so jaskel if your reading this. How did it go, and what was the story with pulling out the fuse? how much did this lower the car?
jaskel
Post by jaskel »
it lowered it a couple inches... here is a pic...the back is sagging a litlle...raise it about an inch and thats it....i would still like to do the spring conversion..
THAWA
Post by THAWA »
Why everyone want to convert to springs instead of air?
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
ciper
Post by ciper »
Because air suspension wears out and is expensive. If you like though I know someone who has a complete working set of air suspension for sale...
THAWA
Post by THAWA »
I'm just curious, I don't have the money for struts right now and if I did i'd most likely be going with gr-2's or some impreza coil-overs
