thought I would start an actual build journal for my wagon
the first bit was all done last year but will give you a brief history of where the car came from and where its going
WHEN I BOUGHT IT
1993 legacy L
N/A, auto, no sunroof
next too my old wagon and donor car
Was fully stripped down and painted 51E subaru aspen white
Car was then put together as a full turbo car with dohc heads vf10 turbo wrx top mount and five speed
STAGE ONE OF CAR ON THE ROAD
wheels got painted 07 STI BBS gold
over the summer the car got a few small things
edm glass headlights
jdm fog lights
06-07 v-limited front lip
and thats how she sat when i parked the car nov. 1 2011
FULL MOD LIST AS OF END OF 2011
Exterior:
full paint job subaru aspen white
turbo hood
turbo bumpers
password jdm rear tow hook
jdm legacy fog lights
06/07 sti v-limited lip
EDM glass headlights with electric leveling motors
4cam 16valve Turbo Intercooled Awd decals
amber removed from rear tail lights
Wheels:
raderwerks p90's 16x7.5 +30
205/50/16
Interior:
98 impreza rs front seats
6.5 alpine type-s speakers
10" JVC sub in custom box built in the passenger storage area
AEM truboost gauge
AEM wide band o2 gauge
alpine i-pod only head unit
cobb double adjust short throw (from an 05 modded to fit)
STI front floor mats
dyed rear floor mats to match sti front floor mats
JDM STI Nardi steering wheel
Suspension:
Bc racing coilovers
front 05 sti sway bar
rear 05 sti sway bar
rear rs lateral arms and sway bar endlinks
camber bolts in rear
Engine and drive-train:
ej22t block with dohc heads
full turbo wiring harness and ecu
newer style coil pack wired into turbo harness
AEM truboost controller
AEM wideband o2
jdm legacy vf10 turbo
04 wrx top mount intercooler
custom intercooler sprayer hooked to 7psi boost switch
relocated coolant reservoir
misimoto y pipe lengthened to fit
subaru group N motor mounts
5 speed swap
maganracing wrx 3" downpipe
full 3" exhaust to magnaflow muffler
walbro 255 fuel pump
Updated Mod list going into winter 2018
1993 subaru legacy wagon
Exterior:
3M 1080 Gloss White vinyl wrap
turbo hood
turbo bumpers
SS Turbo Decal
Antenna delete
Non-turbo grill
Oem Rear lip
Lighting:
3000k/6000k colour switch LED headlights and fog lights
cluster lights swapped to red LED
Wheels:
Miro STP-1 16x7.5 +30
Wheels custom painted 07 STI BBS gold
205/50/16 Firestone Firehawk Indy 500
Brakes:
JDM 4 pot front brakes
Usdm wrx 2 pot rear brakes
stainless lines
Slotted front rotors
Interior:
95 JDM STI Seats
AEM truboost gauge
AEM wideband A/F gauge
dyed black headliner\sun visors\grab handles
Red STI shift knob
STI shifter surround
Output Motorsports reverse lockout
Output Motorsports 6 speed badge
Suspension:
Bc racing coilovers
OBX Trailing arms and Lateral Links
Front JDM STI Strut tower brace
Rear Cusco Carbon Strut tower Brace
Mine's Lower control arm brace
Engine\engine bay and drive-train:
ej22t block
Wiseco .020 forged pistons
Scat Rods
Ver9 JDM STI heads intake avcs
ARP Head studs
Perrin Light Weight Crank pulley stock size
STI oil pump
AEM wideband o2
VF37 Twinscroll Turbo
WRX Dark Blue injectors "565cc"
CX Racing front mount with custom piping
Moroso coolant reservoir
Dual oil catch can
Optima Yellow Top
BWR battery tie down
Custom grounding kit
Killer B oil pick up
Killer B oil baffle
Apex-i intake
AVO Turbo Inlet pipe
STI six speed
R180 rear diff
DCCDpro diff controller
ACT 6 puck clutch
ACT heavy duty pressure plate
ACT street lite flywheel
AVO Turbo Twinscroll downpipe adapter
Ver9 JDM intake manifold (non tgv)
9mm phonolic intake spacers
Synapse BOV recirculated
Ver9 JDM Twinscroll Equal length header. wrapped
Custom Stainless Downpipe 3"
Mishimoto Power steering resevoir with full stainless braided lines
Boomba Fuel Rail kit with full stainless braided lines
Fuellabs -6 fuel filter
Zerosports radiator air guide
Grimmspeed 3 port EBC
Tuning:
Jdm Ver9 Sti Ecu
Converted to OBD2 by I-wire
Open source speed density tune by JM Auto
306hp 350tq
