nosyt's 93 turbo legacy wagon
nosyt
Post by nosyt »
hey guys
thought I would start an actual build journal for my wagon
the first bit was all done last year but will give you a brief history of where the car came from and where its going
WHEN I BOUGHT IT
1993 legacy L
N/A, auto, no sunroof
next too my old wagon and donor car
Was fully stripped down and painted 51E subaru aspen white
Car was then put together as a full turbo car with dohc heads vf10 turbo wrx top mount and five speed
STAGE ONE OF CAR ON THE ROAD
wheels got painted 07 STI BBS gold
over the summer the car got a few small things
edm glass headlights
jdm fog lights
06-07 v-limited front lip
and thats how she sat when i parked the car nov. 1 2011
FULL MOD LIST AS OF END OF 2011
Exterior:
full paint job subaru aspen white
turbo hood
turbo bumpers
password jdm rear tow hook
jdm legacy fog lights
06/07 sti v-limited lip
EDM glass headlights with electric leveling motors
4cam 16valve Turbo Intercooled Awd decals
amber removed from rear tail lights
Wheels:
raderwerks p90's 16x7.5 +30
205/50/16
Interior:
98 impreza rs front seats
6.5 alpine type-s speakers
10" JVC sub in custom box built in the passenger storage area
AEM truboost gauge
AEM wide band o2 gauge
alpine i-pod only head unit
cobb double adjust short throw (from an 05 modded to fit)
STI front floor mats
dyed rear floor mats to match sti front floor mats
JDM STI Nardi steering wheel
Suspension:
Bc racing coilovers
front 05 sti sway bar
rear 05 sti sway bar
rear rs lateral arms and sway bar endlinks
camber bolts in rear
Engine and drive-train:
ej22t block with dohc heads
full turbo wiring harness and ecu
newer style coil pack wired into turbo harness
AEM truboost controller
AEM wideband o2
jdm legacy vf10 turbo
04 wrx top mount intercooler
custom intercooler sprayer hooked to 7psi boost switch
relocated coolant reservoir
misimoto y pipe lengthened to fit
subaru group N motor mounts
5 speed swap
maganracing wrx 3" downpipe
full 3" exhaust to magnaflow muffler
walbro 255 fuel pump
Updated Mod list going into winter 2018
1993 subaru legacy wagon
Exterior:
3M 1080 Gloss White vinyl wrap
turbo hood
turbo bumpers
SS Turbo Decal
Antenna delete
Non-turbo grill
Oem Rear lip
Lighting:
3000k/6000k colour switch LED headlights and fog lights
cluster lights swapped to red LED
Wheels:
Miro STP-1 16x7.5 +30
Wheels custom painted 07 STI BBS gold
205/50/16 Firestone Firehawk Indy 500
Brakes:
JDM 4 pot front brakes
Usdm wrx 2 pot rear brakes
stainless lines
Slotted front rotors
Interior:
95 JDM STI Seats
AEM truboost gauge
AEM wideband A/F gauge
dyed black headliner\sun visors\grab handles
Red STI shift knob
STI shifter surround
Output Motorsports reverse lockout
Output Motorsports 6 speed badge
Suspension:
Bc racing coilovers
OBX Trailing arms and Lateral Links
Front JDM STI Strut tower brace
Rear Cusco Carbon Strut tower Brace
Mine's Lower control arm brace
Engine\engine bay and drive-train:
ej22t block
Wiseco .020 forged pistons
Scat Rods
Ver9 JDM STI heads intake avcs
ARP Head studs
Perrin Light Weight Crank pulley stock size
STI oil pump
AEM wideband o2
VF37 Twinscroll Turbo
WRX Dark Blue injectors "565cc"
CX Racing front mount with custom piping
Moroso coolant reservoir
Dual oil catch can
Optima Yellow Top
BWR battery tie down
Custom grounding kit
Killer B oil pick up
Killer B oil baffle
Apex-i intake
AVO Turbo Inlet pipe
STI six speed
R180 rear diff
DCCDpro diff controller
ACT 6 puck clutch
ACT heavy duty pressure plate
ACT street lite flywheel
AVO Turbo Twinscroll downpipe adapter
Ver9 JDM intake manifold (non tgv)
9mm phonolic intake spacers
Synapse BOV recirculated
Ver9 JDM Twinscroll Equal length header. wrapped
Custom Stainless Downpipe 3"
Mishimoto Power steering resevoir with full stainless braided lines
Boomba Fuel Rail kit with full stainless braided lines
Fuellabs -6 fuel filter
Zerosports radiator air guide
Grimmspeed 3 port EBC
Tuning:
Jdm Ver9 Sti Ecu
Converted to OBD2 by I-wire
Open source speed density tune by JM Auto
306hp 350tq
nosyt
Re: nosyt's 93 turbo legacy wagon
Post by nosyt »
now that we are caught up
since december ive been collecting parts and finally pulled car into garage last night to put it all together for spring
parts pile so far
05 sti injectors
U8 ecu that has been RobTuned
AEM patch harness wired to accept jdm U8 ecu
ACT six puck and pressure plate
Stock 3.9 LSD
Red LED's from V-LED's for cluster lights
EJ20K cams and TD05 turbo
Just pulled motor tonight to start swapping everything i'll keep updates coming as stuff goes back together
also considering STI oil pump while the motor is apart
nosyt
Post by nosyt »
pulled apart the motor tonight to take heads over to buddies house to swap cams and valve springs
The new style hydraulic tensioner - after looking closer today discovered it not only had oil around the pin but had about a 1/4 of play by hand. this will be swapped out for the old style tensioner when it all goes back together
engine bay - needs to be cleaned and have a few wires tucked that were added in after the last time the motor was out
heads - torn down and getting ver.4 sti cams and sti valve springs
old DOHC NA cams that just came out
motor torn down - with a certain purple legacy being worked on in the background
nosyt
Post by nosyt »
sorry for the shitty pics guys
bad camera + bad lighting = shitty pics
CAV3MAN227
Post by CAV3MAN227 »
-Its looking good, I like it! Keep the pics coming!
-Joe
silver03
Post by silver03 »
Outstanding!
nosyt
Post by nosyt »
Little more work done today removed crank gear and old oil pump. the crank gear was a pain in the ass due to some sort of bearing compound the previous owner put between the gear and the crank. also removed the oil pan cleaned it up and resealed it.
then spent most of my night cleaning up the engine bay. relocated my boost switch (pressure activated switch that at 7psi completes a circuit that turns on my intercooler sprayer) and redid the wiring for that. also rewired my fog lights in preparation for the H3 3000k HID's i got for them. and because since my original swap my cruise control doesnt i work i fifnally got around to remoing all the cables and control boxes
nosyt
Post by nosyt »
lots of work done today and it was payday so picked up all my parts from the dealer
grabbed the sti oil pump and o-ring, front crank seal, coolant crossover o-rings, downpipe gasket, head gaskets, all turbo crush washers, clutch release bearing springs, fuel rail o-rings and from the auto parts store i work at i grabbed a timing kit with all pulleys and belt and grabbed both coolant sensors and oil pressure sensor
ill do a better write up later im exhausted after a 9 hour day in the garage
PhyrraM
Post by PhyrraM »
Looks good. Especially the patch harness!
Your not adding AVCS or any other oil comsuming device over stock. So, unless you really opened up your bearing clearances, you only need a small bump in oil pump capacity - if any.
nosyt
Post by nosyt »
yea the oil pump was just one of those while Im in there type things . the ecu is tuned with a 7500 rpm rev limit just want to make sure everything is well oiled at those speeds
nosyt
Post by nosyt »
here is a pic for you guys . motor coming together . all new pulleys on front brackets painted new oil pump block cleaned
Subiman91ss
Post by Subiman91ss »
looks great
91ss sdn 5spd
taking the time to do it right = stress free fun
nosyt
Post by nosyt »
well today i got the intake all taken apart a painted it a long with a few other small pieces
then went over to my buddies house and tore apart the heads
replaced the 25dohc NA valve springs and cams with 04 STI valve springs and ej20k cams and reshimmed the buckets for the new cams
nosyt
Post by nosyt »
so the motor is back together heads on intake and exhaust manifolds and new turbo all plumbed up!
just need to give the engine bay a quick wash and delete the ABS then motor will be back in the car
sorry for no pics on this update been very busy. my father just purchased a 95 legacy wagon that needed a water pump so thats my job tomorrow instead of working on my car
nosyt
Post by nosyt »
not a huge update since last time as i took a break over the weekend from working on my car to working on my dads car :P
so since my chassis is a 93 shell and the harness is from a 92 turbo car the abs plugs were different on the harness so i have never had ABS. finally took the time to T off my brake lines and clean it up and remove the ABS pump
cleaned up motor and heads on. coolant tank relocate to front of intake manifold to allow clearance for top mount
TD05 mounted up
and greddy catch can that is going to go where the abs pump was
nosyt
Post by nosyt »
finished up the timing belt and put all covers back on motor tonight then went about modifying the U8 ecu case to fit in factory location of the legacy one
tomorrow the engine bay gets washed
dads car gets new front brakes
and friday the motor goes into car with first fire planned for saturday if all goes to plan
Nice work!
nosyt
Post by nosyt »
since my modification to the U8 ecu worked so well to mount it in stock location we decided to do the same thing to my brothers ( bmxkelowna ) drift car, this time taking a few pics to show you guys
( sorry we missed pictures for a few steps)
first thing you have to do is take apart the casing from your stock ecu and new ecu pulling the board out of the new ecu by removing the two outer screws.
the stock brackets are spot welded on so just drill those out to remove brackets giving you a nice smooth surface
take the stock ecu and cut the outer ridges off so you are left with a nice smooth surface with the two mounting studs
take your favourite adhesive and attach the two cases together. you can tack weld these together but in our case we used really good double sided tape
finished product after you bolt case back together is stock size and now can be nicely tucked into stock location
That's a pretty neat way to retrofit the ECU.
nosyt
Post by nosyt »
got motor in car today should be fired up first thing in the morning
nosyt
Post by nosyt »
so the car has been on the road for close to two weeks
been busy driving it hence the lack of posts
car at home jdm fog lights with H3 3000K HID's installed
motor all together catch can installed
got an apexi intake today for it
sounds a lot nicer and seems to pick up quicker too
im still having issues with the car not being able to run anything over wastegate boost as it stumbles trying to go wide open throttle and anything higher
Subiman91ss
nice car.. came together really well. give me hope for mine :)
91ss sdn 5spd
nosyt
Post by nosyt »
thanks man !
im excited to see what it will run like when its running full boost cause she is quick at 9psi
nosyt
Post by nosyt »
well i was finally able to figure out my stumbling issue the coil was bad resulting in blowing out spark
swapped that out and car runs great and very fast up to 18psi
updated mod list
current spec
Exterior:
turbo hood
turbo bumpers
rear password jdm tow hook red
Lighting:
H3 3000K HID bulbs in fog lights
Wheels:
205/50/16
Interior:
AEM truboost gauge
Suspension:
Bc racing coilovers
ej22t block
dohc heads
EJ20K cams
04 STI valve springs and retainers
STI oil pump
Aurora ignition wires
AEM wideband o2
TD05 Turbo
05 STI yellow top injectors "550cc"
Custom intercooler sprayer controlled by 7psi boost switch
Greddy oil catch can
Apex-i intake
5 speed swap
ACT 6 puck clutch
Tuning:
93 JDM WRX ECU
AEM patch harness to convert from 4 channel to 2 channel ignition
custom RobTune chip
tuned for 18psi
7500 rpm rev limit
launch control
CEL triggered by knock sensor
robertpaige
Post by robertpaige »
Nice bump lol
But seriously my favorite TW.
