How much does your Legacy Turbo cost you in a year?
teaguespeed
I was just wondering how much you guys spend on you legacy turbos in a normal year, excluding oil changes. I have been considering getting another next summer, but the one i have has been a bit expensive, mostly because of a blown head gasket. Explanations would be cool, maybe include how many miles are on your car.
'99 Impreza L 2.2 powa!
"If at first you don't succeed, failure may be your style."
Well mine has cost me more than 2 g's replacing a bunch of original items with STi items... clutch, flywheel, engine mounts, tranny mount, full suspension, and some non STi stuff, ss brake lines, fluid, pads, rotors, calipers, turboback exhaust. But most people wouldn't do that all that....
Maitenance wise so far it will need a heater core... and I replaced one of the half-shafts, and a busted coolant line. Just about the only unexpected expenses. Does that number include gas?
I will have to see what the car will need next year to better determine up-keep (I keep up-grading
boostjunkie
Mine has been more costly in my time more than anything else. I figure I've spent upwards of $300-400 on the car since I've got it, but DAMN, there's A LOT of man-hours involved troubleshooting all of my problems.
Let's see:
TB coolant line blew out - freaked me out, thought I blew a hg!
MAP sensor went up
idle switch/TPS
washed engine, whole HELLUVALOT of problems
damn gorilla nuts siezed, preventing me from undoing lug nuts.
See my posts for more info.
I'd say total, the car's been down for repairs (although minor) for about a month during the year or so I've owned it.
Let's see:
MAP sensor went up
idle switch/TPS
teaguespeed
In the last year, i've probably spent zero $$$ on my car.
Seriously.
I haven't done a thing to it since i put the coilovers on it, and got the Prodrive wheels early this year.
Maintenance has been non-existent, i just drive it and it goes.
Seriously.
Legacy Central
I've owned mine for about 3 months, and I have spent $300 so far, I expect to spend about another $700 in the next few months. Once I get everything fixed, I expect to spend very little on it...
[color=red][b]1993 Subaru BC Turbo Legacy (193k miles)
1971 VW Super Beetle
1989 Honda Elite 50
[/color][/b]
1989 Honda Elite 50
[/color][/b]
legacy92ej22t
Well I put $500-800. I replaced the rear rotors and pads, both front axles, 1 wheel bearing and seals, turned front rotors and replaced pads but have new front rotors on hold till I cream the ones I'm using, MAF sensor, O2 sensor, front seals, timing belt, rigged coolant fill tank, new NGK plugs, K&N panel filter, and alternator. I still need to replace valve cover gaskets. Some of this stuff wasn't vital to replace though either, like the MAF. I have to say though that I've had the car since 96 and till this past year I only replaced the front brake pads once and bought new tires, thats it!
Stuff that REALLY didn't need done that I spent money on in the last year( not included in poll ): Installation of Turbo-back exhaust, Saab 900 tmic purchase and install, oem WRX 16" wheels and tires, OBX race boost gauge, Joe-p mbc, Momo Euro edition aluminum shift knob and oem WRX hood scoop.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
- quasi-mod-o
you need a higher category
FrmRgz2Rchz
This might be a bit much, but here is my mainenance log. I bought the car in 04/03. The log shows it, too
12/1/95 ---12,000 Oil Change -----------------15
1/17/96--- Parking Brake Tightened ------------15
6/24/96 ---Oil Change -------------------------15
11/1/96 ---Oil Change -------------------------15
2/17/97 ---Fix Flat Tire --------------------------5
4/12/97 ---Oil Change -------------------------15
5/24/97 ---Clutch Replaced -------------------300
8/13/97 ---Radiator Heat Shield Repair ---------50
11/1/97 ---Windshield Wipers ------------------10
1/7/98 ----Oil Change --------------------------15
8/14/98 ---Oil Change -------------------------15
8/27/98--- Repaired Sunroof -------------------50
12/2/98 ---Oil Change -------------------------15
4/14/99 ---Check for Sunroof Leak-------------10
5/14/99 ---Dealership Repared Sunroof ------100
9/7/99 ----Oil Change -------------------------15
10/2/99 ---Front and Rear Brakes -------------75
6/9/00 ----Oil Change --------------------------15
6/25/00 ---New Tires --------------------------200
9/24/00 ---New Battery ------------------------60
3/16/01 ---Oil Change --------------------------15
5/12/01 ---Radiator Heat Shield Repair ---------50
11/9/01 ---Tail Light Repair --------------------50
12/26/01-- Oil Change ------------------------15
12/26/01 --Radiator Heat Shield Repair -------50
1/2/02 ----Tune-up, Radiator Flush -----------300
5/13/02--- Oil Change -------------------------15
9/12/02 ---Oil Change -------------------------15
1/10/03--- Front Hood Repair -----------------100
4/25/03 ---Coolant Hose ----------------------10
5/5/03 ----Oil Change ---------------------------0
5/11/03 ---Saab 900 TMIC ---------------------0
5/20/03 ---Autometer Boost Guage ------------55
5/28/03 ---Oil Change -------------------------20
6/10/03 ---Manual Boost Controller ------------50
6/22/03 ---TD05 Turbo -----------------------320
7/5/03 ----Cat-Back Exhaust -----------------140
7/17/03 ---Oil Change -------------------------20
7/17/03 ---K&N Air Filter ----------------------40
7/29/03 ---ACT Clutch Kit -------------------380
8/10/03 ---Greddy Type-S Blow Off Valve ---127
9/22/03 ---Fuel Cut Defender ----------------12
10/5/03 ---Front Brakes ----------------------21
10/27/03-- Oil Change -----------------------15
11/26/03-- 4 Dunlop Graspic DS-1 Tires----240
11/26/03 --Mount/Balance/Alignment --------50
11/26/03 ---Front L/R CV Axles -------------120
11/28/03 --Turned Front Rotors ---------------0
11/28/03---F/R Brakes ------------------------65
12/1/2003--Oil Change ----------------------15
$3320 in recorded mechanic work
Andy Rose
1993 Subaru Legacy Sport Sedan
2003 Subaru Impreza WRX
2004 Subaru Impreza WRX STI
1999 Hyundai Accent
1999 Hyundai Accent
FrmRgz2Rchz
