Strong shudder as engine shuts off only when hot
91Beater
Post by 91Beater »
Title says it all. My 91 shudders strongly when the engine shuts off, but only after the car is fully warmed up.
I'm guessing motor mounts, but why only when hot? I don't want to dismiss other possibilities and would like some input.
lucas
Re: Strong shudder as engine shuts off only when hot
Post by lucas »
grab ahold of your engine and try to shake it by hand if you get excessive play then probably motor mounts
1993 legacy ss "Shela"
Does the entire car shudder or just the motor? Can you give us any more details?
91Beater
Post by 91Beater »
Legacy777 wrote:Does the entire car shudder or just the motor? Can you give us any more details?
It almost feels similar to the shudder you feel when you almost stall a manual car. All cars vibrate a bit when you turn off the engine, but mine shakes enough to feel like a shudder and only when its fully warmed up.
jp233
Post by jp233 »
is this an EJ22 or EJ22T?
might be trying to diesel a tiny bit ("run-on") so I would check the resistance of the fuel injectors to see if it's squirting some extra fuel in there and its catching a spark. Also timing or TPS?
Motor mounts, obviously check those.
12 Outback 3.6R Limited
94 Leg LS wag AWD, sold
93 Leg L wag FWD, sold
06 LGT 5EAT, project
91Beater
Post by 91Beater »
jp233 wrote:is this an EJ22 or EJ22T?
EJ22. TPS has already been adjusted.
