Garage Door Lip
originalcyn
Garage Door Lip
Post by originalcyn »
I know there are a couple threads about this, but I had to reattach mine after a scrape with a curb, so I thought I'd take some pictures.
So here we go:
I was screwing mine in to the bottom of the bumper, which in retrospect was not a great idea. But, having already made a bajillion holes on the first go around, I realized that it wasn't sustainable, and that the next time I damaged the lip the front bumper would be completely shot. So, solution...speed clips.
This is a role of the material I used, I could only find a suitable piece at Lowe's. Everything anymore is some kind of soft rubberized foam. This is still rubberized foam, but it's A LOT more firm. In any case, i'll try to get a upc or something.
While at Lowe's, I also purchased some 26 gauge sheet metal to make braces with,
which we then cut in to thin strips,
and some rounded corner pieces.
Here's the first brace going on from the underside.
And the next corner piece going on. We had to cut reliefs, a couple small cut out triangles, at the corners.
Here's an outside view of how it's going on at this point.
Most of the underside just calls for small 6 or so inch braces. Two pre-drilled holes and bent up a little to add pressure.
Fine adjustment so it floats around evenly (ish). I'll have to heat gun it a tad to get a couple of the waves out.
Finished product (minus heatgunning).
Kijan
1993 Legacy LS | PBM 227
Re: Garage Door Lip
Nice work. Quite thorough. I'm impressed.
Re: Garage Door Lip
Are all of your friends' faces pixilated?
originalcyn
Re: Garage Door Lip
Thanks Kimo.
Beatersubi, Yeah, they're all in the witness protection program. Haha, nah, I wasn't sure if they wanted their faces everywhere online so it was easier to just pixelate them out than ask them.
Kijan
Re: Garage Door Lip
Looks good man!
silver03
Re: Garage Door Lip
Post by silver03 »
excellent and simple write up. (I love simple)
originalcyn
Re: Garage Door Lip
Thanks guys. still don't have that upc, but at some point...
Kijan
Apex3
Re: Garage Door Lip
Post by Apex3 »
Great ideas! Might have to take them if/when I put one back on my car.
originalcyn
Re: Garage Door Lip
Apex, don't you have some kind of crazy awesome lip? your car was always one of my favorites.
Kijan
92wagon
Re: Garage Door Lip
Post by 92wagon »
It looks good! thank you for the write up!
CAV3MAN227
Re: Garage Door Lip
Post by CAV3MAN227 »
-I dig it! Nice simple mod!
-Joe
originalcyn
Re: Garage Door Lip
Haha, if only i could claim credit for having thought of it in the first place.
Kijan
Apex3
Re: Garage Door Lip
Post by Apex3 »
originalcyn wrote:Apex, don't you have some kind of crazy awesome lip? your car was always one of my favorites.
Haha well thank you :D
And I did, I lost it to the assholes that set up the entrance to one of the Oregon trail rally stages
originalcyn
Re: Garage Door Lip
Alright, as promised (months ago) here is the information about the garage door seal I used.
Purchased at Lowe's
UPC 04337407234
M-D Building Products
Hope that helps!
Kijan
