bad temp sensor
turbo970
bad temp sensor
Post by turbo970 »
could a bad temp sensor make a car bog down when trying to accelerate and make the car die?
Re: bad temp sensor
It's possible. Does the car start ok? Does the issues it experiences change when the engine is warmed up?
Typically issues with the coolant temp sensor will be different when the engine is cold vs. when it is hot. It may run fine when cold, but crappy when hot....or vice versa.
turbo970
Re: bad temp sensor
Post by turbo970 »
well i think i found the main problem of the subie
Re: bad temp sensor
For completeness & future searching/reference, please try and keep all information about the problem in one thread, and/or link to the other thread so folks can follow it in the future.
Link to new thread
http://bbs.legacycentral.org/viewtopic.php?f=19&t=49845
91Beater
Re: bad temp sensor
Post by 91Beater »
turbo970 wrote:could a bad temp sensor make a car bog down when trying to accelerate and make the car die?
There's a sensor resistance chart somewhere. It shows two points if I recall correctly.
The temperature information is available through the connector and with Subaru scan tool, you can read it. If it corresponds to coolant temperature as measured using surface contact meter where the sensor is mounted, the sensor is ok.
