bad temp sensor
bad temp sensor
could a bad temp sensor make a car bog down when trying to accelerate and make the car die?
Re: bad temp sensor
It's possible. Does the car start ok? Does the issues it experiences change when the engine is warmed up?
Typically issues with the coolant temp sensor will be different when the engine is cold vs. when it is hot. It may run fine when cold, but crappy when hot....or vice versa.
Re: bad temp sensor
well i think i found the main problem of the subie
Re: bad temp sensor
For completeness & future searching/reference, please try and keep all information about the problem in one thread, and/or link to the other thread so folks can follow it in the future.
Link to new thread
http://bbs.legacycentral.org/viewtopic.php?f=19&t=49845
Link to new thread
Re: bad temp sensor
There's a sensor resistance chart somewhere. It shows two points if I recall correctly.turbo970 wrote:could a bad temp sensor make a car bog down when trying to accelerate and make the car die?
The temperature information is available through the connector and with Subaru scan tool, you can read it. If it corresponds to coolant temperature as measured using surface contact meter where the sensor is mounted, the sensor is ok.
