What is this?
maria24017
What is this?
Post by maria24017 »
I was going to check my transmission fluid the other day and saw a hose that isn't hooked up to anything. I don't even see anything near by that it might attach to. It has probably been like this since we pulled the engine.
It has white residue in it.
Any ideas?
1990 Subaru Legacy L sedan 2.2L 4 cyl AWD automatic 122,500
The worst day of your life only lasted 24 hours
Re: What is this?
Hard to say but it could be one of the coolant lines that go to the throttle body
PhyrraM
Re: What is this?
Post by PhyrraM »
The automatics have a breather hose that doesn't connect to anything. Might be it?
Re: What is this?
Post by SILINC3R »
I thing I got the same thing and was wondering too.
kleinkid
Re: What is this?
Post by kleinkid »
This question has been asked and answered here before. I can't remember the answer to everything, and this is one.
EDIT: Found it in the service manual, Section 3 page 104, 1. Air breather hose.
It is open to the atmosphere, the other end goes on a nipple on the converter case case.
maria24017
Re: What is this?
Thanks. I wasn't sure, I hadn't even seen it before and had no idea what it could be... Especially with the white residue in it
Re: What is this?
It looks a little big to be the breather hose, but it may just be the picture.
You should be able to trace it back to the source, and if it's coming from the trans, then yeah it's definitely the breather hose.
