93 ss steering rack
abest10
93 ss steering rack
Post by abest10 »
hey guys, need to know if a 2000 impreza steering rack will fit my 93 ss(from what I read the GC rack is a direct in the 90-94 legacy). My rack is rusted and leaks like a stuck pig. Also should I grab the PS pump off the impreza so it will make the swap easier? Or can I re use my legacy PS pump with the impreza unit?
1993 Legacy SS 5 speed sedan
Re: 93 ss steering rack
I believe the 00 Impreza rack should be compatible. I'll let others chime in because I'm sure a few have done the swap.
I don't think you'd need to swap your PS pump unless you wanted to.
abest10
Post by abest10 »
Alright thanks for the input Josh. I may just swap the pump too because it is starting to leak as well. Im hoping the junkyard impreza is in ok shape and I can make out with a good rack and pump. (fingers crossed)
Someperson
Post by Someperson »
we all like a good rack and pump
93 Winestone TW project
I have a feeling it is a direct fit as well. I do know that the stock PS pump and lines are compatible.
abest10
Post by abest10 »
So I confirmed over the weekend it's a compatible rack and actually takes the same inner and outer tie rods.
Good deal!
Thanks for following up.
