4EAT won't engage after service, need help!
Ok guys I decided to service my 4eat. Replaced filter and gasket. After filling back up with fluid I overfilled it and now it won't engage at all! I went to drain a little bit of fluid from drain plug and no fluid at all came out? What the heck did I do? I tried to warm up car and that didn't work. I also left it in reverse and drive for several seconds and still nothing. Need help fella's!!
1994 Legacy Sport Wagon (EJ22T)
1977 Leone 4X4 Wagon (EA72)
Re: 4EAT won't engage after service, need help!
There are two dipsticks. Which one did you fill? One is trans fluid and one is gear oil.
Charles
Holy shit! Obviously not the right one. I pulled the dipstick out from the one I filled and it says "diff" on it. Crap... Where is the tranny dipstick?rallyak wrote:There are two dipsticks. Which one did you fill? One is trans fluid and one is gear oil.
Well crap, I found it...I'll add it to the right place this time...should I just drain the front diff and refill with gear oil?oleman77 wrote:Holy shit! Obviously not the right one. I pulled the dipstick out from the one I filled and it says "diff" on it. Crap... Where is the tranny dipstick?rallyak wrote:There are two dipsticks. Which one did you fill? One is trans fluid and one is gear oil.
Someperson
Prob ur best option
93 Winestone TW project
Well that's a first for me. Dang I feel stupid!Someperson wrote:Prob ur best option
Do you know how much oil the front diff takes?oleman77 wrote:Well that's a first for me. Dang I feel stupid!Someperson wrote:Prob ur best option
My source says 1.5 qts but that a Haynes manual, could be wrong.
Charles
Ok I'll start there. Thanks...rallyak wrote:My source says 1.5 qts but that a Haynes manual, could be wrong.
Well it helps when you add fluid to the right place after a service. All is good....oleman77 wrote:Ok I'll start there. Thanks...rallyak wrote:My source says 1.5 qts but that a Haynes manual, could be wrong.
