4EAT won't engage after service, need help!
oleman77
Post by oleman77 »
Ok guys I decided to service my 4eat. Replaced filter and gasket. After filling back up with fluid I overfilled it and now it won't engage at all! I went to drain a little bit of fluid from drain plug and no fluid at all came out? What the heck did I do? I tried to warm up car and that didn't work. I also left it in reverse and drive for several seconds and still nothing. Need help fella's!!
1994 Legacy Sport Wagon (EJ22T)
1977 Leone 4X4 Wagon (EA72)
rallyak
Re: 4EAT won't engage after service, need help!
Post by rallyak »
There are two dipsticks. Which one did you fill? One is trans fluid and one is gear oil.
Charles
oleman77
Post by oleman77 »
rallyak wrote:There are two dipsticks. Which one did you fill? One is trans fluid and one is gear oil.
Holy shit! Obviously not the right one. I pulled the dipstick out from the one I filled and it says "diff" on it. Crap... Where is the tranny dipstick?
oleman77
Post by oleman77 »
Well crap, I found it...I'll add it to the right place this time...should I just drain the front diff and refill with gear oil?
Someperson
Post by Someperson »
Prob ur best option
93 Winestone TW project
oleman77
Post by oleman77 »
Someperson wrote:Prob ur best option
Well that's a first for me. Dang I feel stupid!
oleman77
Post by oleman77 »
Do you know how much oil the front diff takes?
rallyak
Post by rallyak »
My source says 1.5 qts but that a Haynes manual, could be wrong.
Charles
oleman77
Post by oleman77 »
rallyak wrote:My source says 1.5 qts but that a Haynes manual, could be wrong.
Ok I'll start there. Thanks...
oleman77
Post by oleman77 »
Well it helps when you add fluid to the right place after a service. All is good....
