How to fix lifter noise on an EJ22T
oleman77
Post by oleman77 »
Ok guys, I have had a knocking/ticking noise for a while and decided enough is enough. I suspect it is the lifters making the noise. I have read a few topics on it and learned a little bit on how to do it but I couldn't find a video showing how to bleed HLA's. So I went ahead and took some videos and pictures step by step on how to do it. Here's what I came up with:
http://www.youtube.com/watch?v=8OVBPnukR4w
1994 Legacy Sport Wagon (EJ22T)
1977 Leone 4X4 Wagon (EA72)
SiCkSTi04
Re: How to fix lifter noise on an EJ22T
Post by SiCkSTi04 »
I've been putting off doing this to my ss but have done it before on a previous legacy L model. Thanks for posting this up and with great results too.
Very nice tutorial, thanks for sharing!
Another way to bleed them is to use a 10mm socket. They fit in the socket and you can pour a little bit of oil in the other end of the socket, press the ball check valve and press the lifter up and down a couple times to bleed the air out.
I'll add this to the engine forum sticky thread.
oleman77
Post by oleman77 »
SiCkSTi04 wrote:I've been putting off doing this to my ss but have done it before on a previous legacy L model. Thanks for posting this up and with great results too.
Its real easy to do as well. It took me longer because I took the time to take pictures and videos but if I was to just go for it would only take about an hour each side. Its one of the easiest you can do and get good results. Good luck, hope your results are as good as mine......
oleman77
Post by oleman77 »
Legacy777 wrote:Very nice tutorial, thanks for sharing!
Thanks Josh...I'll use a 10mm socket next time. After driving it around a bit I still have a bit of noise, but its way better. I made one mistake, I didn't check all the HLA's like I should have. Only had 2 that seemed bad which I bled and replaced. Should have checked the other six to double check they were good, they seemed bled and solid but I should have performed the bleeding procedure on them to see that they pumped smoothly. I might do the procedure again and double check the other 6 since its not that bad of a job. I also plan to do an oil change, I was told to use Rotella T6 5W-40 Synthetic but it seems a bit on the light side. The temps here in NM don't get that low, might see zero a few times a season but mostly in the 20's at night. I know Rotella is a great oil but after reading several posts it seems this could be a factor for noise as well. Its seems the oil of choice is Mobil1 10W-30, so I will change to that and see how it goes.
Yeah, I would definitely suggest bleeding all of them, plus with using the 10 mm socket it orients them so the bleed hole is at the top so as long as their good, you should not have any air in there.
SiCkSTi04
Post by SiCkSTi04 »
Yea I recall it being a pretty straight job. I also have a full sandwich bag full of spare lifters. :)
martimus919
Post by martimus919 »
Something we used at Lexus was amo packaging to hold the lifters in place and put it in a container where we could just run through all of them real fast.
07 Outback XT VF52
94 Legacy Sport, VF23, 550 RobTune, various other things
93 Legacy Touring Wagon EJ205 management and dash swap (in progress)
90 Loyale Turbo, EJ Turbo Swap, 2" lift
82 Brat, EJ22 swap, RX AWD trans w/ LSD rear, 5 lug 4 wheel disc.
