Group N Mounts
GTwagon
Group N Mounts
Post by GTwagon »
hi everyone,
sorry to start another one but i cant seem to find what im looking for in search.
im in need of new motor and trans mounts.
i've seen this on ebay and am not sure if i need to 5 speed or 6 speed.
they all look the same to me.
im looking at this kit here.
do i want to 5 or 6 speed kit?
http://www.ebay.com/itm/150972123383?ss ... 1423.l2649
if n e one knows where to get them cheaper that'll be nice also but im not holding my breathe on that one :-D
Drive it like you Stole it
rallyak
Re: Group N Mounts
Post by rallyak »
I believe you want the 5spd mounts. I bought mine at Rallispec the guys there know there stuff.
Charles
GTwagon
Re: Group N Mounts
Post by GTwagon »
rallyak wrote:I believe you want the 5spd mounts. I bought mine at Rallispec the guys there know there stuff.
k thanks,
i want to see "YES" thats the one you want lol
always on a budget so dont want to order it twice :-D
Re: Group N Mounts
Yes, you want the 5spd "kit". The engine and pitch stop mounts are the same between the 5 & 6spds, however the trans mount is different.
Personally, I'd price out what the engine & trans mounts run from one of the online Subaru dealers. I personally don't think the group n pitch stop mounts do anything but add nvh to the cabin. For example, I input all those part #'s into subarugenuineparts.com's catalog and the price was $231.41 vs the $257.00 on ebay.
Other thing to note is that people are selling these mounts as "group n" mounts, and they're just US STi parts, not group n mounts. The original STi group n mounts have part #'s that start with STi. Is there a difference between the parts....I don't know....probably not, but just an FYI.
Baddog
Re: Group N Mounts
Post by Baddog »
I bought the Megan racing mount set for my girlfriends 92 legacy. I have Subaru "Group N" in my car right now. Comparing them they were the same stiffness.
I would buy the Megan Racing kit and save some money. They even have Subaru part numbers on them. They just have their sticker on them.
http://www.ebay.com/itm/Megan-Racing-Mo ... cb&vxp=mtr
1996 Subaru Legacy L
1993 Subaru Legacy SS
1992 Subaru Legacy L
1990 Subaru Legacy L
Re: Group N Mounts
What if he has a 6 speed?
Re: Group N Mounts
If he's got a 6 speed get the 6 speed mount. If not get the 5 speed mount. It will make your life a lot easier. It was a huge pita to get my pitch mount bolted in because I used a 6 speed groupN mount and its shorter in height which drops the trans down and angles the engine back more causing the bolt holes to be off on the pitch mount about 1/2-3/4 of the width of the hole. I had to redrill my mounting bracket out.
GTwagon
Re: Group N Mounts
Post by GTwagon »
kimokalihi wrote:If he's got a 6 speed get the 6 speed mount. If not get the 5 speed mount. It will make your life a lot easier. It was a huge pita to get my pitch mount bolted in because I used a 6 speed groupN mount and its shorter in height which drops the trans down and angles the engine back more causing the bolt holes to be off on the pitch mount about 1/2-3/4 of the width of the hole. I had to redrill my mounting bracket out.
also the 5 speed model will work for my auto 4eat?
Re: Group N Mounts
No it won't fit an auto. I believe there is an aftermarket company making auto bushings, you might have to do a search for it.
GTwagon
Re: Group N Mounts
Post by GTwagon »
mike-tracy wrote:No it won't fit an auto. I believe there is an aftermarket company making auto bushings, you might have to do a search for it.
damn it not what i want to read :(
Re: Group N Mounts
Rallitek makes one for the auto, and prob other companies too.
glennda5id
Re: Group N Mounts
Post by glennda5id »
I have the Rallitek mount insert in 01 H6 Outback. I have the racing version. I can feel every piston fire at idle....
Overtime though it has softened a bit, but it basically turns the 4EAT mount into a solid piece. Originally I thought it was too harsh, but now I like it.
glennda5id
Re: Group N Mounts
