 Cracked some ribs snowboarding, Hurt way to much to sand, so the project was put on hold yet again. Built a mini Booth and Tried sandblasting wheels. Way to time consuming, gave up, took them to a U-Blast Place.
I sidetrack easily, projects include :
A Sandblasting Booth :
Gave that up and took them somewhere else. Way to time consuming. Need at least a 7.5HP Compressor.
The Wheel Collection, Minus a Second set of Speedline Pero-R's ( FOR SALE )
They I Built a Powdercoating Oven :
Began Powdercoating :
Got the wife's Professionally done :
First one turned out a little Crinkly, but OK. Gold with Satin Clear :
Powdercoated the Centers Gold, with Gloss Clear. Bolts Olive Drab & Got the Lips Polished and I coated them with Sharkhide protectant :
Had some Insulation left over from the Oven, decided to do the Garage Door :
Then I wanted to get my chairlift Modified and hung. Chopped it, welded it, hung it. Porch Swing :
Ok, Enough time wasted. Back to the Subie. NOS OEM Fender. Car still Bent
   Seems like you are the type to try them all out for looks no?
