94 Legacy Wagon New Speaker connection Issue
94subarulegacy
Post by 94subarulegacy »
I have a 1994 Subaru Legacy Wagon and the back speakers are dead so the plan was to replace them. I bought some Infinity 6032cf 180 watt Speakers. The fit fine with the adapter that came with it. The issue is that the plug on the car is |-- (roughly) and the new speakers are set up -- --. So I am unable to just plug in the new speakers. I was wondering what should be done. I just thought today that I might be able to just touch the right contacts and then tape them together. I will put up some pictures for reference. If you could tell me what to do or what I should buy that would be great.
Crappy Pictures:
http://imgur.com/a/j2YeV
1994 Subaru Legacy Wagon L
rallyak
Re: 94 Legacy Wagon New Speaker connection Issue
Post by rallyak »
On my rear speaker I just cut the oem plug off and soldered the right connectors on the wires.
Charles
94subarulegacy
I actually have found the adapter I needed.
http://a248.e.akamai.net/pix.crutchfiel ... 071003.PDF
http://www.amazon.com/gp/product/B0002B ... UTF8&psc=1
Hopefully all will work out.
That's a cool little adapter!
I usually just cut the OEM conenction off and put new spade connectors on, but that adapter is pretty slick.
