Needed 91 Legacy VLSD SS turbo rear axle stub/axle
Whiteghost2.5
Post by Whiteghost2.5 »
I need an axle for a 91 turbo ss legacy VLSD with unequal length passenger side stub. Please email me pics to FTmyers70@msn.com
Need one asap.
heres what the axle will look like (thanks to mike-tracy)
Last edited by Whiteghost2.5 on Wed Mar 27, 2013 5:51 pm, edited 3 times in total.
sqc151
Re: WTB: Legacy SS turbo rear axles
Post by sqc151 »
will any of these work for ya?
Whiteghost2.5
nope thanks tho. looking for one with the longer male splined axle
Longer male stub. I thought all turbo legacy axles were the same between the models, aside from front and rear...?
sqc151
Post by sqc151 »
That's what I thought.
I thought the top 2 were what he might have needed, guess not unless he needs 2 male ends.
But either way, they are here.
For reference, bottom 2 came off the front.
The "longer male splined axle" is actually a normal 90-94 legacy rear axle with the differential stub still attached. There's a roll pin holding the stub on to the axle.
ex. (missing the driver side stub)
Ohhhh i see...
sqc151
Post by sqc151 »
So my axles are correct but he needs the stub.
Should probly edit the first post saying he needs the diff stub. His post says he just needs an axle.
Oh well, gl in ur search.
On a side not...Wow, that diff needs help... haha.
Ok, second question, all the first gen legacy rear diffs i have seen have had male stubs coming off the sides.
Are you saying that rear diff is just missing a piece?
The male stub itself is seperable from the diff?
If so....
Can you just grab the piece from any first gen legacy rear diff? It seems like you can since all the first gen rear axles are the same fitment. And all the first gen front axles were the same fitment.
If his diff is non-vlsd then he can grab a stub from another non-vlsd 90-94 Legacy. 91 SS VLSD diffs used weird unequal length stubs.
Whiteghost2.5
I need the SS VLSD unequal length axle passenger side!!!
Sorry I was not specific
Thanks guys
Whiteghost2.5
I have seen a couple people on here with them but no responses to my pm's
Just make sure you're making it clear that you're looking for the 1991 Legacy SS passenger side stub, not the axle- since those are identical to all 90-94 legacy ones..
Here's a picture from the passenger side. Note roll pin: Punch that out and it separates unequal length stub from standard axle.
Sorry about the tease, I already sold the diff & stubs.
Whiteghost2.5
Ahhh that's excellent info. Thank you. Now I just need the stub shaft.
Whiteghost2.5
Re: Needed 91 Legacy VLSD SS turbo rear axle stub/axle
Bump up. I need the above pictured splined stub
Whiteghost2.5
Thanks for the info mike-tracy.
http://www.subarupartswebsite.com/OEMPa ... AA001.html
Anyone looking for the stub here it is
Whiteghost2.5
OK the stub shaft is no longer avail from subaru. I need one damn
That's a bummer.
Alphius
Post by Alphius »
That's really hard to find. Only the '91 Turbo Legacy used the stub with the VLSD drive splines to my knowledge. You might end up having to buy a new VLSD diff with the stubs included if you can't find one. Newer Subarus with a VLSD diff used an axle with a male end instead of a seperate stub. I don't know if you could convert to that style of axle.
Disclaimer: I may be wrong. Still hard to find. Good luck.
Whiteghost2.5
I may have found a savage yard with a few legacy ss they are going to call me if the have the axle!!
Whiteghost2.5
ok does it have to be out of a 91 ss manual car. the axle is $285 shipped so i need to make sure its the right one.
thanks
Alphius
Post by Alphius »
You don't need the axle. You need the stub out of the diff. If you order an axle you will not get the stub.
It's only on '91 Legacy SS with VLSD rear diff, yes.
Place he's talking to said they won't separate stub from axle.
Alphius
Post by Alphius »
For that price I would put a non-VLSD stub in it and wait for a better price. Sure, the rear will act like an open diff but it's better than nearly $400. Damn.
