Well when I installed my sub and amp last week I might have overlooked a few things being in a rush.
Problem 1: when turning the car to the on position before I crank I get two slight jumangi thumps from the sub with about a second or two in between. Then also when I crank it on it will do one to two thuds. And when I mean slight literally if you picture the jumangi beat when its in the ground
Solution 1: me being in the rush I ran the power cable, rca cables and the lil blue p.conn wire all through the same side of my car.... I didnt think much of it until I tucked/taped all the wires together and realized I usually run the rca cables and other lil blue wire on the passenger side.. are these wires all ran/bundled together causing that weird thump OR...
Problem 2: this happened last night after NOT starting the car all day(I usually start my car up everyday by 10am for errands/work/etc, well last night it was completely dead and in the on position without cranking the light thump was going ape shit like I had the jumangi game in my trunk! I ended up jumping it and it fired right up. My guess is I may have wired the lil blue wire to the wrong blue wire behind my deck. I just connected it to a blue wire that I thought I had cut before from my last system but then I was reading through the install instructions where it says I should connect the pconn wire to my power antenna wire(which is blue as well and I cut along time ago when I bought the car) so the blue power antenna wire IS NOT connected to anything and I have the blue pconn wired to a rando. The whole system works and hits fine but I'm thinking since I let the car sit all day the amp drained the battery
Problem 3: the green power light on my amp is ALWAYS on since its getting direct power from my yellow top...this also confused me cuz shouldn't it shut off when the car does??
Is me not having the blue wire connected to the proper power antenna wire causing the amp to always stay on? Is the job of the blue wire to tell the amp to power down when I turn the car off like the power antenna would if it were hooked up?
