cranks over but wont fire
slickmasterc
Post by slickmasterc »
hello i ran the subbe dry and then put $5 fuel in her, but it still wont fire, i have gone thru 3 charged batterys for it to fire and no luck. any suggestions?
Subaru 89 Legacy GT 2.0 Turbo AWD
Mazda 93 323 Familia 1.5 SOHC FWD
Yukonart
Cradle Robber
Cradle Robber
Post by Yukonart »
Check spark plugs
Wires
Distributor
:P
Good luck!
THAWA
Post by THAWA »
no distributor to check
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
Yukonart
Cradle Robber
Cradle Robber
Post by Yukonart »
THAWA wrote:no distributor to check
D'oh! Missed that!
Guess I'm used to this being an issue on even older cars. :oops:
(Showing my age)
Sheesh... he goes and gets a fancy 2004 STi and forgets all about how advanced BC/BFs are...
slickmasterc - Did you run the engine to the point where it completely stalled out from lack of fuel? Is it possible the pump has to be primed or something? I wouldn't think so, since I've never heard of it being done, but... just thinking out loud.
You basically need to check that you are getting spark and fuel. A timing light is a good way to check for spark. But your problem is most likely fuel anyway.... can you hear the fuel pump energize for a few seconds when you turn the key to the "ON' position if you listen for it? When you try to crank the engine, can you hear the injectors click with a stethoscope?
Yukonart
Cradle Robber
Cradle Robber
Post by Yukonart »
vrg3 wrote:Sheesh... he goes and gets a fancy 2004 STi and forgets all about how advanced BC/BFs are...
That pretty much sums it up. I never have the time to look under Laurel's hood when she comes up to see me. ;)
THAWA
Post by THAWA »
hahahaa, sorry dirty mind and all.
Yukonart
Cradle Robber
Cradle Robber
Post by Yukonart »
THAWA wrote:hahahaa, sorry dirty mind and all.
Oh yeah. . . . I meant under Ruby's hood, too. ;)
I just thought of something, slickmasterc. I believe our fuel pumps are meant to be cooled by the fuel flowing through them. If you had a somewhat old pump the begin with, and overheated it by running the car out of fuel, that may have killed it.
morgie
Post by morgie »
don't forget to check fuel pump connector under rear seat !
this was my problem :)
morgie
'98 4Runner V6 Manual 4x4.
LegacyT
Post by LegacyT »
Water - condensation in the fuel tank.
Mark,
ciper
Post by ciper »
Check the voltage supplied. On my XT6 the fuel relay would trigger but it wouldnt run. I finally checked the voltage and it was 9 volts! Couldnt find the bad ground spot so I just got a wire splice (clamps onto a wire and adds a seperate lead) and bolted it to a new ground.
SHADO
Post by SHADO »
Ya i had dis problem a while back on my Legacy, we took the fuel pump out and noticed that one of the wires going into the fuel pump had melted, we just soldered it back.
czo79
Post by czo79 »
Fuel filter? Sometimes if there is a lot of crud in a tank, and you run it way way down, it might get sucked up, and clog your filter or something....
Of course I've also noticed that subaru tend to have about a gallon in reserve, that can't be used, you'll run out of gas and its still in there. I think this tends to prevent that problem...
but its worth a shot.
Mike K
Micum
97 Legacy 2.5 GT - mod'd
93 Impreza L AWD (sold)
97 Legacy 2.5 GT (deceased)
98 Legacy Outback (sold)
georryan
Post by georryan »
I'm with Morgie, check the electrical lines under the back seat on the right hand side of the car. I had to splice my wires and put in a new connector.
91 Pearl White Sport Sedan
2014 Volvo S60 T5
18 KTM 1290 Adventure S
97 Toyota 4Runner SR5 - sold
2002 BMW r1150rt-p - sold
2004 BMW r1200ST - sold
2016 BMW r1200RS - sold
