Pretty sure I killed my front diff somehow..
Danny
-Installed a better, newer, more accurate boost gauge than what I already had.
-Joe
-Joe
Auto in my sedan went out today, spent most of the day waiting for a ride home to get a tow rig to get it home and got it home at 8:45 tonight. Turbo wagon time now.
Danny
Danny-was it giving signs of going out over last months or outta nowhere?!
Lets see I changed my oil, added Lucas no slip shit to my tranny fluid and drained about 2-3 qts out! My dipstick was double over F with checking the right way.....also changed the fuel filter, the old one didn't have too much crap in it surprisingly
Also installed some kartboy ss and bushings in my buddies new turbo baja
It started making noise yesterday, now it makes all sorts of terrible noises and I have to rev it to almost 4k to get it moving at all.
Danny
So before yesterdays noises it wasn't starting to slip or feel sluggish? Or you could give it the beans when you wanted?
It didn't seem any bit slower and it was putting the power down fine. The noise first started while I was on the highway with the cruise on doing about 60.
Danny
getting the oil hanged and having the brakes looked over.
-Plasti dipped my front grille.
-Joe
-Joe
Pics? I've been thinking about doing the same to mine.CAV3MAN227 wrote:-Plasti dipped my front grille.
-Joe
1994 Subaru Legacy L Winestone Pearl
-Sorry, but taken right now, suns going down. More cow/panda:
-$6 a can here in Denver at Lowes.
-Joe
-Joe
Washed it and found out the fucking sunroof leaks... I am so close to just swapping shells with my parts car. I HATE that sunroof!!
Danny
hit big nw, sold/picked up some parts etc
Installed my front & rear strut tower bars.. I don't think I'll have the front one for very long. I bought a hood for my car but its the 92 year shade silver, not my quicksilver metallic.. Sucks. I'll be tossing in a 3.9 lsd rear differential soon.
Subaru-less
-Actually yesterday, but finally got my intake fixed. Re-routed some breather lines to clean things up.
-Joe
-Joe
installed my replacement boost gauge
Removed the snorkus and planned my coffee cup mod. It's going to be a real clean install. Might be willing to fab up a few if any body is interested.
Grille work.
-Drove to work and eleven hours later, drove back lol!
-Joe
-Joe
Hooked up the switch for the amp I don't currently have in the wagon and removed the brake booster vaccum line from the sedan so the breaks are more like rally car brakes.
Danny
Put a ten and twelve inch sub in, along with a 1000 watt amp. Audio system is almost complete, just need to ground the last amp and install the new front speakers.
Danny
extra motor in garage now..
Resealed metal cover beneath flywheel, new rear main seal, resealed the other piston ring access plate, front cam seals, resealed oil pump and new front main seal, valve cover gaskets & bled lifters, resealed oil pan.
Subaru-less
Decided that the mbc needs to come out, I'm tired of hitting fuel cut.
Danny
-Hit 225,000 miles yesterday
-Joe
-Joe
