Engine idles high some times
Nibbib
Post by Nibbib »
So like the title says my car will idle high but normally only happens when I fill the car up at a shell gas station with 92 but other times it will do it if I get on it hard with 2nd and 3rd but normally doesn't happen too often but the car is a 93 touring wagon with 16g turbo air water intercooler 3 inch down pipe and a 5 speed swap
I'm just wondering if anyone has had this issue before and could shed a little light on where to start looking for issue
Thanks, cody
rallyak
Re: Engine idles high some times
Post by rallyak »
I would clean iacv that fixes mine.
Charles
Nibbib
Post by Nibbib »
Okay where would the iacv be located which side of the manifold and what would be the best why to clean it
Did you do the 5spd swap or was it done by a previous owner?
The IAC valve is on the passenger side of the intake manifold and has a 3/4" hose coming off of it into the resonator box.
Nibbib
Post by Nibbib »
5speed was done before me and okay thanks and would you just recommend replacing it instead of cleaning it I was reading up in some of it and some people will just replace them instead of cleaning them
rallyak
Post by rallyak »
Replacements are around 200-400 I would just clean it, it's a lot cheaper. I clean mine yearly that's about 50-70k usually every fall.
Charles
wtdash
Post by wtdash »
- Off-topic, probably, but are you running any EM - piggyback, Revtronix chip, EJ20G w/Rob Tune, etc? If not, be careful w/the TD05 if you're still running the stock injectors, etc.
Read up on here about using this turbo, as it can max out the stock setup and could cause issue$.
TD
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
Nibbib
Post by Nibbib »
There is no tune yet and the boost hasn't been increased and what should I use to clean it with
Nibbib
Post by Nibbib »
Also could be a o2 sensor?
wtdash
Post by wtdash »
There's a Thread on here about cleaning the IAC, - use brake cleaner - not WD40-type stuff.
Probably not the 02 as it doesn't do as much on our OBD1 cars as the '95+ OBD2 cars that have 2 of them, but if it's original, I'd replace it as it can help your MPG.
TD
Turbo Subies:
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
Nibbib
Post by Nibbib »
Okay I did found one thing that someone mentioned don't remember who but said putting sea foam in the vacuum hose coming off of it
