free5ty1e
Post by free5ty1e »
Added a 3" cat and replaced my crushed muffler with a glass pak. Gotta pass oregon emissions soon and register my car here.
Sent from my SAMSUNG-SGH-I337 using Tapatalk 4
-Chris
91SS 4EAT stock, 200k mi
turbo970
Post by turbo970 »
hooked up a double din dvd player just need to find a trim piece to fill in the gap at the bottom
free5ty1e
Post by free5ty1e »
Ripped out the auto seat belt computer from my 92 autotragic so they stop trying and failing to move all the time. Ghetto manual belt conversion complete.
-Chris
James614
Post by James614 »
Got my GD WRX coil packs all wired up to pop onto my EJ20G. Now I can kick my ignitor to the curb!
Danny-G
Post by Danny-G »
Tinted the corner lights amber, replaced a fog light bulb, painted the scoop, painted the thing that feeds the chimney, and fiddled with the mbc. Planning on clearing my passengers headlight then baking both tomorrow.
Danny
Danny-G
Post by Danny-G »
Just needs a good bath and polish before wcss.
Danny
Pulled my broken engine, and started assembling my good block.
Any chance youll be done in 4 days mike?
Danny-G wrote:Image
Looking good Danny
dillonr92
Post by dillonr92 »
ImageI fixed my loose factory cigarette lighter and wired two others in.
Also while I was down there I noticed these un plugged blue "T" connectors and two other with no mates any idea what the blue one are and where the other go??||Image
92 SS winestone red. td04 - FMIC. RWD 5 spd swap/LSD.dead...
94 LEGACY GT RAISED ROOF WAGON, fozzy lift hydro clutch/91SS 5speed/VLSD..#5.NEW FuLL DRiFT SLuT 93SS winestone,RS 5speed RWD. Welded rear, td04, fmic, 17x9 +20
randomiam
Post by randomiam »
I've been putting a lot of miles on my little wagobeater but the brakes are overdue for repair so it was sidelined for my trip this weekend. I got my rebuilt alternator back from the shop in Kent (the rebuilder) and got it squared away and its back running and reliable once again. I drove about 600 milesish this weekend, averaged 23MPG hwy but pretty damn aggressive driving.
Took a new route north up the east side of the Cascades in Oregon.. My goodness, some awesome roads and scenery:
Subaru-less
free5ty1e
Post by free5ty1e »
dillonr92 wrote:...Also while I was down there I noticed these un plugged blue "T" connectors and two other with no mates any idea what the blue one are and where the other go??||Image
I believe the T shaped connectors are your "green" active diag connectors, used here, 3rd paragraph.
I believe the yellow connector is your Subaru Select Monitor / OBD1 diag connector; this actually fits a radio / head unit harness adapter and can be wired into various OBD1 diagnostic tools / circuits as detailed here
EDIT: Incidentally, I still have my B10 scan tool working on a dedicated old DOS laptop under my passenger seat. If anyone's interested to see one work, I can demo @ WCSS15.
Am planning to wire in a serial port to this setup so I can make use of a newer laptop and perhaps RevScan or EvoScan, too. Hopefully in time for the show :)
-Chris
Those are blue, not green. That has something to do with the dashboard, just can't remember off hand. Yes the yellow plug is SSM, the little black plug is for diagnostics in the seat belt system. if you follow it up a couple inches you will come across a loose wire that is taped to it. You use that loose wire (plugging it into one of the slots in the plug) to read error codes from the seat belt computer.
free5ty1e
Post by free5ty1e »
Indeed, those are blue... didn't realize we had blue "T" connectors under there as well!
Now I'm curious what those are for. :)
-Chris
The blue T connector should be connected. It's a ground related wire
CAV3MAN227
Post by CAV3MAN227 »
^I have wondered the same about all those connectors, thanks for explaining guys!
-Joe
No problem
free5ty1e
Post by free5ty1e »
Passed oregon DEQ emissions with my '94 ss and freshly installed catalytic converter. The readout stayed dead center in the green zone the entire test. Go Subaru!
However, I find now that because I have an oil drip from behind my timing cover on my 92 ss and the exhaust piping smokes that oil...it wont pass inspection.
I just got 21 day temp tags for them both, and now gotta scramble and try to replace my cam / crank seals and valve cover gaskets before the tag expires so I can go get it to pass DEQ with no smoking. Thats gonna suck in my tiny 1car garage but thats the plan!
Still gotta find a good subaru alternator to put in the 94 ss before the road trip up to WCSS15!
-Chris
randomiam
Post by randomiam »
Borrowed a evoscan? cable from Mike.. Been doing a bit of logging at a few different boost levels trying to figure out a few things; Pretty interesting. I hit a strange fuel cut limiter on the revtronix chip at a certain set of parameters; Need to just keep reading and figure out what is normal, what isn't, limitations etc.
took my 95 LS wagon on a dump run, car weighs ~3128lb empty ish, without me and minimal gas. Wonder what the SS is at. Guessing ~3000
Subaru-less
free5ty1e
Post by free5ty1e »
Reran alternator cabling nicely... 4gauge wire direct to battery, orig fusebox remainder wired to battery terminal. Cleaned all connections and replaced a twisted barely functional positive battery terminal. Going to start it up tomorrow and take measurements, then if all is well going to register this 94ss in Oregon!
Then its timing belt time for the 92ss....
-Chris
Chrisg03
Post by Chrisg03 »
SO i finally did my whole brake system :)
JDM 4pots up front (5mm spacer to run bugeye rims)
05 LGt rear brake setup and goodridge stainless steel braided lines feel pretty dam solid compared to before and stops about the same
Always open to learn
turbo970
Post by turbo970 »
replaced my inhibitor switch. the new one came with a white tab but didnt see where it went so til i find out its in my glove box
Pulled an engine out of a friends impreza to replace a bad auto trans for him. Yeah its not my subie, but I'm "spreading the love"
No homo...
Sent from my SGH-T989 using Tapatalk 4
CreepyOldGuy
Post by CreepyOldGuy »
Replaced my dead knock sensor - no more CEL and it seems to run better too.
1994 Legacy Wagon AWD MT 230,000 miles and counting (Winter beater/commuter)
1990 Miata (Track toy and summer commuter)
1998 Land Rover Discover (Off road toy and money pit)
2000 Diesel Excursion (Family truckster and tow beast)
dillonr92
Post by dillonr92 »
Not somthing I did to my subi but I fojnd these head lights and grill... I want them badd. Dose anyine know what spec car they came off or anything?? Image Image
