I can not for my life figure out the size of this starter nut. I have went to the hardware store and bought every bolt that looks about the right size, but none of them fit. M8 is too small M12 is too big. M10 fits on there just right but I can't figure out the correct pitch. I tried m10x1.00 and it doesn't go on, same with m10x1.25 and m10x1.50. But i'd figure it would be one of those, am I just stupid and I can't get the nut to go on to the stud?
And yes, I have searched all over here, all over nabisco, I can't find anything on this nut size.
Start nut size
Re: Start nut size
Maybe it's a 1.75 pitch. I know some of the metric bolts are impossible to find at hardware stores, especially the fine thread metric bolts.
You are talking about the lower starter stud nut....correct? The 17mm hex size?
If you take the starter to a machine shop, they should be able to help you figure out the thread pitch....and might have a nut. I usually have better luck with machine shops then hardware stores around here.
maciek puszynski
16 WRX | 6mt | fa20
2.36L Turbo - RSTi Build
16 WRX | 6mt | fa20
Re: Start nut size
It's a 17mm nut with 14mm bolt threads So a standard exhaust nut and wide washer will work if you cant find the 17mm nut.
Re: Start nut size
The stud is attached to the transmission I'm pretty sure... I wish I could just find where I put it lmao.
Re: Start nut size
I'm retarded....it is attached to the bellhousing. I just had to drill and tap my RS transmission bellhousing to be able to run the ej22t block.
Make sure the threads are not compromised on the stud. If there is a damaged thread, it might make it difficult to get even the correct nut started.
maciek puszynski
16 WRX | 6mt | fa20
16 WRX | 6mt | fa20
Re: Start nut size
RileyD wrote:The stud is attached to the transmission I'm pretty sure... I wish I could just find where I put it lmao.
I'm having the same issue with all the screws from my interior center console, had a bag full of screws and such, cannot find them for the life of me my garage is like a black hole.
Have you considered rethreading the stud?
