CJ's Prefaced 92 SS build 22T/205 Hybrid - Legawrex
Re: CJ's Prefaced 92 SS build...
If the block and or heads have been decked then it looks like it's "almost" off a tooth. No way to get it perfect without fancy adjustable sprockets that I don't think they make for phase I dohc heads.
I did get the timing correct. I have had the heads resurfaced once. This time I counted the teeth to make sure it was correct. The timing is now off but maybe off by the thickness of one of the cam gear marks.
There are cam gears but they're 300-500 for the set.
Im still battling a hesitation issue, its just not as bad.
You can use adjustable idler pullies like I did. Crawford and I think someone else makes them.mike-tracy wrote:If the block and or heads have been decked then it looks like it's "almost" off a tooth. No way to get it perfect without fancy adjustable sprockets that I don't think they make for phase I dohc heads.
http://www.main.experiencetherave.com/s ... G_2709.JPG
http://www.main.experiencetherave.com/s ... G_2720.JPG
Hmmm, ill have to check out prices.
The ones for Crawford are kind of pain to adjust due to the large 1-1/4" size. You really need an offset wrench. I didn't want to drop a fortune for the wrench, so bought a cheaper regular 1-1/4" wrench at harbor freight and a buddy cut and welded it for me. It worked great.
http://www.main.experiencetherave.com/s ... eadwork/22
The other manufacturer uses an allen wrench type setup to adjust their idler pullies and I would think that is easier to adjust.
Just bought a used turbonetics deltagate mark 2 on ebay for 55 shipped.
I keep spending money when I shouldn't. Megan racing headers, 20 bucks used. Needs a 1/4" crack welded and a stud drilled and re-tapped. Fits regular oil pan.
Will be going on relatively soon.
free5ty1e
...I know THAT feeling, lolcj91legss wrote:I keep spending money when I shouldn't
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
-Chris
91SS 4EAT stock, 200k mi
Haha, yeah... super good deal I couldnt pass up.
Sent from my Samsung Galaxy Note 2.
Ordered a dump tube and an elbow for my ewg. Also some stuff to build an fcd.
More boost soon, excited..
It finally showed up!!!
free5ty1e
Ooh thats purty. Chris likey.
-Chris
Yeah ive never physically seen an ewg, so when I opened the box I was like holy f*** thats huge. And this is just a 38mm..
scored a good deal on another set of wrx ignition coils. Interesting how the table of parts in my garage is accumulating...
Rebuilding the td04 i got from patrick at bnwsm and will be installing that and a 06 tmic on the white 93. Also ordered a rebuild kit for my VF39 as well.
Hate the cold, I kind of want to install a heater in my garage.
Looks like I have some stuff to do now...
free5ty1e
Ooh a VF39 and rebuild kits... whats the turbo on the right?
-Chris
Thats the td04 for my girls 93 SS. Its going to gwt that and an 06 tmic real soon. Along with a 5MT swap.
ride_child
yea finding good deals and spending money you shouldnt. i mean i know ive never done that...
Kris
'91 Mica White SS - R.I.P.
'91 Black SS - SOLD
'91 Black SS - SOLD
Well I'm having an issue that's quite a pain in the ass today. Day before yesterday crush washer on my oil feed line on the top of the turbo decided to start leaking. Called my buddy and for a great buddy deal I had my car towed home. Figured it'd be no big deal, I have a brand new Kinugawa SS oil feed line. Swap it out and check oil and presto. Everything worked out, except there's still a leak. HMMMMM (is this thing anti turbo?)
Anyways, I realized my drain line (it's a crazy concoction) was leaking as well. (When I first put the engine together I honestly didn't know there was a difference between heater hose and pcv hose (lesson learned awhile ago.)) So Today I pulled the turbo, Now the reason why I have this crazy concoction of an oil drain tube is because I have the twin turbo heads. The drain tube goes off to the passenger side of the car instead of straight up like SS or WRX & STI. I wish I would have fixed this 4 years or so ago. Now I'm battling with trying to figure out how to rotate the tube with the engine in the car and bla bla bla.....
Also found this cool piece of flex pipe in my uppipe (pre flex.) Thankfully it hasn't been the reason for grenading a turbo, but wow. Talk about a close call...
Well, I have a rod knock. Did a compression test today before yanking the motor out. 30psi in cyl 1 and the gauge was bleeding down fairly quick. 140psi on the other three cylinders. Seems weird i was able to drive it home without even feeling like it was running on three cyl. Whatever....
I'm shopping for a good used ej20 now.
free5ty1e
Oh lame!
-Chris
It happens I guess. Block took 4-5 years of a rough beating.
robertpaige
Awh man you're going to an EJ20?! Just rebuild the 22t.
Depends on how the 2.2 is and how much maxwell wants to charge me for custom pistons for the +2mm manley rods I have.
