EJ22T stroker w/ EJ20 WRX heads Comression?
Baddog
Post by Baddog »
I am going to be building an Ej22T with 5.18" Phase 1 rods w/ 52mm journals, Ej251 crank, have the block machined for the #5 thrust, and the weisco pistons for the 2.35 stroker. Will be running the WRX ECU/Harness/IM/Heads.
Curious on the compression ratio of this engine.
1996 Subaru Legacy L
1993 Subaru Legacy SS
1992 Subaru Legacy L
1990 Subaru Legacy L
86BRATMAN
Re: EJ22T stroker w/ EJ20 WRX heads Comression?
Post by 86BRATMAN »
The ej20 heads are 49cc, if I'm not mistaken the stroker pistons are advertised as 8.5:1 with the 46.6 ej25d heads. Without getting into real calculations it'd be 8.3-8.4:1
macipusy
Post by macipusy »
8.3:1 CR sounds right for that setup.
What rods are you using that are Phase 1 with the 52mm journals? I'd be interested in learning about these, since it is a much easier route to the Phase2 crank in Phase1 motor stroker build then the custom piston route I took.
maciek puszynski
16 WRX | 6mt | fa20
2.36L Turbo - RSTi Build
Baddog
Post by Baddog »
The rods will be scat 5.18" rods with the 52mm journal. Ej251 crank. Thrust conversion. Weisco pistons
Baddog
Post by Baddog »
What HG do you use? Ej22T? or Custom cometic?
Mister Anderson
Post by Mister Anderson »
On my hybrid engine I will be running the stock HG thickness for the EJ25D heads, but with a bore size correct for a EJ22T. Cometic makes a decent amount of off the shelf thicknesses for the EJ22T.
Here is my thread that shows the relocation of the thrust bearing; http://bbs.legacycentral.org/viewtopic.php?f=5&t=52349
If you are in Portland I would take it to Bearing Service Co. They have done it a few times.
91 black SS 5 speed (Canadian).... Closed deck EJ20G, fully built, V5/6 sti ra drivetrain, haltech stand-alone
93 silver TW 5 speed... rebuilt 22T with 20G heads, wrx ra drivetrain, otherwise stock.
73 kazen red VW bus riviera camper
