Im going to replace the main and rod bearings, my question is, is there anything wrong with mixing ACL H(STD) & ACL HX(STD) bearing to make a complete set?
I don't have a complete set of either one , but put together I have a set. Their both standard, I believe one is coated and the other is not.
So if I put the two together, is that OK?!
To clarify , #1,3,5 are HX and #2 & 4 are H
I'm not mixing a half bearing with another half bearing..if that makes sense.
Plastigage #'s
#1 and #5 are .0015
#2,3,4 are .002 give or take a little
