Questions regarding main bearings
dankberries
Post by dankberries »
I'm currently knees deep in rebuilding the engine from my 93 SS.
Im going to replace the main and rod bearings, my question is, is there anything wrong with mixing ACL H(STD) & ACL HX(STD) bearing to make a complete set?
I don't have a complete set of either one , but put together I have a set. Their both standard, I believe one is coated and the other is not.
So if I put the two together, is that OK?!
To clarify , #1,3,5 are HX and #2 & 4 are H
I'm not mixing a half bearing with another half bearing..if that makes sense.
Plastigage #'s
#1 and #5 are .0015
#2,3,4 are .002 give or take a little
93 impreza rally muffin
89 Nissan 240sx sr20
90 Nissan 240sx 2jz
Re: Questions regarding main bearings
You could probably do it, but I personally probably wouldn't.
rallyak
Post by rallyak »
Your oil clearances are good, I don't see why not. I probably would,engines are not that picky, and if it saves money do it.
Charles
dankberries
According to the FSM:
.0004 - .0012 in.
#1 & #5 limit .0016
# 2,3,4 limit .0014
My #2,3,4 are between .0015-.002 which I guess is little loose than stock.
I wish I had a the right kind of mic for the job and I could come up with a more accurate measurement.
90 Nissan 240sx 2jz
Mister Anderson
Post by Mister Anderson »
dankberries wrote:According to the FSM:
.0004 - .0012 in.
#1 & #5 limit .0016
# 2,3,4 limit .0014
I used plastigauge when I checked mine.
