legacy troubles, please help!!
Hey guys, i got my 1993 legacy a couple months ago and last weekend it just died on me when i was coming home and havnt been able to get it started again.
I checked the oil, batt, gas, sparks are good.
I was reading online and some people said it could be the timing belt, the ignition, alternator.
Was just hoping to get a little more info, anything will help
Thanks guys.
Thanks guys.
Re: legacy troubles, please help!!
Alt I'm thinking. If it died on you.
							1991 subaru legacy sport sedan
				Someperson
mileage?
93 Winestone TW project
Pop off the timing belt access cover and check the belt/tension.
				Someperson
^+1
^+2, more than likely its the belt.
							Charles
204xxx miles
				robertpaige
More info please. Does it crank over? Does it try to start and sputter? Or does it not hold a charge?
				Someperson
^probably timing if its at 204...
Yeah, the engine shakes and everthing, just doesnt completely start.
If it isn't timing, I just had the same deal and turned out it was corrosion in the harness at the fuel pump. Just have to pop the access cap in the trunk. It is secured by four screws.
							Rusty 1991 EJ22T - VF28 - '07 wrx TMIC - MBC - Invidia DP - Walbro 255 SOLD
1992 Legacy SS 5mt, with some neat stuff on it
Do you have the link to order them?
Thanks guys,
Greatly appreciated.
						Thanks guys,
				Someperson
Radio shack
				robertpaige
To order what?
Also if the plug looks okay, you can pull the inlet line off the fuel filter, turn the key and see if it pumps fuel out of it.
