Dominator
Post by Dominator »
What brand? It does look nice. I've been eyeing a Mishimoto rad lately, but I don't need it yet.
smitysubaru
Post by smitysubaru »
Dominator wrote:What brand? It does look nice. I've been eyeing a Mishimoto rad lately, but I don't need it yet.
Sent from my HTC One_M8 using Tapatalk 2
this radiator is actually a eBay replica of the popular koyo R2218 which is a direct and perfect fit for my swapped EJ20G impreza! A real koyo is $300 so yeah for the money I paid this thing is high quality. The worst that could happen is the radiator leak which is a easy fix.
http://pages.ebay.com/motors/link/?nav= ... 45&alt=web
CAV3MAN227
Post by CAV3MAN227 »
-Put on a GFB Response BOV.
-Joe
turbo970
Post by turbo970 »
hooked my ppi pc 2150 and ppi pc 225 sounds good to me
Amps?
turbo970
Post by turbo970 »
yup yup the ones from the late 90's
Raquon
Post by Raquon »
My Mercedes projectors came on, started to wire them, going to try to put them in tomorrow
Dominator
Post by Dominator »
Right on! Definitely keep us posted. I'm very curious to see how they come out. I've wanted to retro fit a pair for my car too, but the fluted lenses have discouraged me.
Raquon
Post by Raquon »
Dominator wrote:Right on! Definitely keep us posted. I'm very curious to see how they come out. I've wanted to retro fit a pair for my car too, but the fluted lenses have discouraged me.
I will make a write up when I finish
CAV3MAN227
-Hooked up the TurboXS FCD to the TW. Now pushing 15lbs in 5th gear.
-Joe
Nice. After I install my blitz boost controller I'm upping the boost to 19ish and I'll see what my afr is.
So I went ahead and got yet another Subaru...
Pretty nasty rear lh quarter panel damage. 4eat. running on 3 cylinders right now, may also have a lights knock. I'm gonna grab a set of injectors and a coil from the wrecking yard this week. Hopefully the 2.5 is sill good, I'm wanting a break from motor work lol.
Dominator
Post by Dominator »
Getting back to working on my T-belt replacement. Here's the block and pump surfaces all cleaned up. Also, I planned on checking the screws, and loctite-ing them securely when I replaced the o-ring. Glad I checked. :shock:
Raquon
Post by Raquon »
Finished them, with one minor setback. PO replaced the driver side headlight with something aftermarket ( I couldn't tell ) and it melted in pretty bad. Next time I'll make sure it says subaru in the lens. Going to the junkyard to get another one and swap lenses.
I will need to angle them down a ways too.
Overall for under $60 I am happy with them
dillonr92
Post by dillonr92 »
You shoulda cleared them lenses atleast a circle 2 inches wider than the projector
92 SS winestone red. td04 - FMIC. RWD 5 spd swap/LSD.dead...
94 LEGACY GT RAISED ROOF WAGON, fozzy lift hydro clutch/91SS 5speed/VLSD..#5.NEW FuLL DRiFT SLuT 93SS winestone,RS 5speed RWD. Welded rear, td04, fmic, 17x9 +20
Raquon
Post by Raquon »
dillonr92 wrote:You shoulda cleared them lenses atleast a circle 2 inches wider than the projector
They're a lot clearer than you think.
I spent time to wet sand , use brush on rubbing compound then buffed them.
dillonr92
Post by dillonr92 »
Oh for real?
I was just saying if they were 100% clear it would be that much more sharp and crystal light. They are a 100% difference from stock tho. They look good man. Good job. I'm planning on doing the morimoto mini h1's.
Raquon
Post by Raquon »
dillonr92 wrote:Oh for real?
The actual projector lens needs to be cleaned just took them apart.
CAV3MAN227
-Picked up some 440cc injectors today, but do have some questions on if they will work at all. (refer to link)
http://bbs.legacycentral.org/viewtopic. ... 98#p428398
-Joe
dankberries
Post by dankberries »
Pretty much sums up my day:
Thing just started dumping fluid like a water fall, thought the car was on fire. POS auto trans! To the curb! 4.11 5speed in route.
Did pads and rotors a few weeks back as well:
93 impreza rally muffin
89 Nissan 240sx sr20
90 Nissan 240sx 2jz
dillonr92
Post by dillonr92 »
So I've put racks on.
Got a forester fog switch to wire to my new 1250 lumen led bricks.
Also got a vw/audi over battery fuse box I am using as a distribution box so there is not so many wires on my terminal.
Bought new calipers and pads and slotted rotors. annnd Did a detail for a new bad ass sub and good amp.
Gonna find out here in a few minutes after dinner if any of my ideas worked. .
The box has three small fused power wires.
I used those for all my lights. the other main connections I used for the fuse box,starter, amp, and power inverter.
And hopefully I can get the forester switch to turn on and off my new fogs.
I like that distribution box.
Dominator
Post by Dominator »
I like the look of your car in that picture. Perfect height / stance. That is a nice distribution box. What model VW/AUDI would that come out of?
CAV3MAN227
dillonr92
Post by dillonr92 »
Thanks guys. It's been a lot of work to get it here.
And I believe it was a 2001 jetta or gti. the popular one.
It needed some modding to fit the subaru wire connections. I'm relieved that everything works great.i figured there would be some BS hang up. the forester switch needed some wire testing but got it figured out..
