I have no RSB ('93 L), and have stock suspension with 200k miles. Current alignment is .2 positive camber!
I'm not sure if I'm keeping it, or plan to sell the car in the near future for an Impreza OBS when the right one comes around so I don't really want to replace struts etc, just looking for some better handling in the meantime, and evening out tire wear.
My questions are: Is it even worth trying to get better handling on original struts and no RSB (rear sway bar) or should I just cool it with fun driving for now? Have any of you non-RSB owners had luck with this?
Will negative camber help any with body roll issues? Seems like body roll is helping to topple over the 0 camber tires resulting in using outside edge and partial sidewall for hard cornering. Will negative camber help with this, or is that on the RSB, struts, or better tires to do that?
Is -1 front and back noticeable over say -1 front and -.5 rear? Just trying to figure the difference in alignment numbers when it comes to no RSB.
Thanks in advance.
