1990 legacy ej22 - smj pin out - anyone have it?
jimkelly1964
Post by jimkelly1964 »
;-) there are 2 smj's in my harness, the smaller one seems to be for power windows, the bigger one seems ot have important engine running stuff running thru it and i need a pin out of it. i has 1-6 columns and a-p rows. thanks jim
http://www.914world.com/bbs2/uploads/po ... 555611.jpg
Re: 1990 legacy ej22 - smj pin out - anyone have it?
Here's a list of service manuals we have posted:
http://bbs.legacycentral.org/viewtopic.php?t=14485
jimkelly1964
some good stuff there but no 1990 legacy smj pin out : ( that i could find. thanks though.
dankberries
Post by dankberries »
You won't find an exact pinout, but you can follow what wire leads to it and back out.
For example, ECU plug B58, pin 7, leads to SMJ plug B27, pin O5.
Everything you should need is in the electrical section of the FSM.
93 impreza rally muffin
89 Nissan 240sx sr20
90 Nissan 240sx 2jz
jimkelly1964
darn. i think i will cut all wires on both sides of both smj's, tape them together, and pull as many loose wires as i can. i also look a wire diagrams to see if i can figure out where inbound and outbound wires go. thanks guys.
Here are the 90 Legacy wiring diagrams
http://main.experiencetherave.com/subar ... agrams.zip
