So early today i got out and start my car and move it so i can shovel some of the 2+ feet of snow around it. Everything works fine.
A couple hours later I try to start it and it wont start. It started once for a couple seconds, then died. Now it cranks but wont start. I'm pretty sure its not a fuel problem. Im getting error code 55 but the list i have doesnt have that number listed.
Does anybody know what the error code 55 is for OBD-I subarus?
thanks
car wont start, error code help
EJ20impreza
95 Impreza L - EJ20 swap
- quasi-mod-o
There is no code 55, Legacy777's site doesn't have one and neither does my Haynes manual, try double-checking the code...
1993 Citroën XM Turbo C.T.
1993 Ford Spectron XL-T
1991 Fiat Croma 2.0T i.e.
EJ20impreza
Clear the codes......or better yet, connect the green & black connectors for the d-check mode and see what happens......if it detects a fault some where.
This is probably no help at all, but the guide at http://www.ultimatesubaru.net/Manual/mi ... codes.html says that on some Subaru engines, error code 55 meant a problem with the "
"EGR Temperature Sensor or Circuit." The same section of the chart includes codes relevant to Imprezas, so maybe an EJ18 ECU uses that code too.
EJ20impreza
