Can the control arm be removed without destroying?????
turbonator
Post by turbonator »
Just wondering I bought used control arms and someone told me that they could not possibly have control arm bushings.
Is this true???
EJ22TGC8
Post by EJ22TGC8 »
I assume that you are wondering if the bushings have to be replaced when you change control arms. I just swaped my control arms out with some used ones and the bushings were fine. You just need to check and see if they are in good condition. If there are then keep them and if they aren't then buy some new ones and have them pressed in.
turbonator
Wow I did not realize my question was so dumb but you answered perfectly.
I bought used control arms to replace the original ones and I was told that the bushings would be no good how much are new bushings for these cars??
