Just wondering I bought used control arms and someone told me that they could not possibly have control arm bushings.
Is this true???
Can the control arm be removed without destroying?????
turbonator
I assume that you are wondering if the bushings have to be replaced when you change control arms. I just swaped my control arms out with some used ones and the bushings were fine. You just need to check and see if they are in good condition. If there are then keep them and if they aren't then buy some new ones and have them pressed in.
turbonator
